OEM Gas tank
Old Mar 5, 2018 | 02:57 AM
user 47363638's Avatar
user 47363638
Default OEM Gas tank
Hey I’m looking at getting a new set of tins for my ‘97 Dyna and wanna make sure they are OEM. From my understanding their should be the HD shield stamped inside the gas inlet somewhere, the ones I’m looking at has something else. How else can I tell if it’s OEM and did HD ever use someone else to do their tanks, I’ll post a picture later.
Old Mar 6, 2018 | 10:30 PM
aces&8s's Avatar
aces&8s
My Evo tank has the "bar & shield" emblem stamped in the filler hole ring. Also if the tank has orig HD paint job. I found a perfect used tank for $300.
Old Mar 6, 2018 | 10:33 PM
aces&8s's Avatar
aces&8s
Need to know if the tank is for a carb bike or FI model. I think 96 thru 05 are the group yrs.
Old Mar 7, 2018 | 05:42 AM
grbrown's Avatar
grbrown
Wink
Doesn't matter who makes genuine Harley stuff - that is what it is! We know who makes some of their parts, but the full extent of what they buy in isn't known. If any of their tanks are made outside, they will be made to meet Harley specs and will carry routine Harley markings.
Old Mar 10, 2018 | 11:07 PM
Hammertime1978's Avatar
Hammertime1978
tJust my 2 cents but, I've found that V-twin Mfg makes tanks exactly to OEM specs. I ended up having to replace the tank on a 95 dyna wideglide and I got it from them and it was exactly like the oem tank. I'm suspicious that they made the stuff for Harley at one point and time. If your not dead set on paying extra for that bar and shield marking, they are the way to go.
Old Mar 13, 2018 | 09:36 AM
twospeed's Avatar
twospeed
Hammertime1978 is right about about giving them a try. They do have some great stuff at great prices. And even stuff no body else has.
As far as making stuff for Harley. As far as your suspicions are concerned, You're dead wrong. I first started dealing with Ted in 1969 when he and his father were selling old parts out of his barn on his property in upstate NY. In those days there were very few aftermarket parts available. You had to make your own. The only aftermarket parts available were from AEE, Custom Cycle Engendering, and an outfit in Chicago that I forget their name. But Ted had all the old stuff and you had to go and dig it out, sometimes go up to the loft and find stuff, if he'd let you. Then you had to promise him that you wouldn't cut the stuff up and customize it. Which is exactly what I did. Then he would ban me from buying his stuff. Then we would talk, and he would let me buy more stuff only to ban me again.
He is a Great guy to deal with. But no he did not make stuff for HD. He was a collector. Until he opened V Twin. Then he had his stuff made over seas and went into a partnership with Wyatt Gatling. ( That's just a company name on paper and he may own that business as well)
Quite a bit of the Harley stuff is not made here in the US. And some of the stuff are parts sourced overseas, and assembled here in the US and marked as either USA, or assembled in the US.
If you cant tell the difference between junk and good parts by examining them, then pay the "hundred dollars" the HD stands for, and be happy the you have a genuine HD box. but that too may be made outside of the US as well.
Old Mar 13, 2018 | 10:23 AM
Hey Man's Avatar
Hey Man
I'm not impressed by parts "made to Harley specs." I don't know if they still do but for years Harley had their spark plugs made by Champion to Harley specs and they were garbage. The Harley plugs made to Champion specs to fit Harley's were far superior.
As far a gas tanks go, all you have to do is hold the tank to tell if it's factory or after market. The factory tanks always felt heavier and sturdier. The gauge of the metal is obviously heavier.
Also reference to V-Twin Manufacturing/Tedd Cycle, I'm not sure just how much of their stuff they actually manufacture. I'm pretty sure most of their stuff is knock-offs of other people's designs made in China, Taiwan, Korea or elsewhere. Hence the nickname "Tiawan Tedd's." OCC is a huge customer of Tiawan Tedd's.
Old Mar 13, 2018 | 01:51 PM
Rt13MFer's Avatar
Rt13MFer
Be careful with V-TWIN stuff, More than a few times I had to modify their "made to HD specs" stuff to get it to fit on a stock HD. Just sayn...
Old Mar 13, 2018 | 02:09 PM
Beemervet's Avatar
Beemervet
True of most aftermarket parts, but particulary V Twin.
Old Mar 13, 2018 | 05:08 PM
Hammertime1978
Cool bit of history there. Thanks man. Personally I've had good luck with all their products I've bought. Only hiccup I've come across was trying to find a seal kit for their edart brake caliper. I tried using the Ultima seals but they were a hair to big and ended up leaking. They only thing I can find is the full rebuild kit for $55. Would you happen to know if the O-ring and seal kit for the GMA calipers would work?
knuckelheader
Oct 13, 2012 01:45 PM
kfmilburn
Mar 23, 2012 05:06 PM
y22c
Jul 29, 2010 08:53 AM
Doug45601
Dec 21, 2007 10:29 PM
panz4ever
Panhead
Jun 29, 2006 03:00 PM
