Couple of newby questions
Old Mar 21, 2018 | 06:12 PM
barneyboy's Avatar
barneyboy
#1: Excessive heat from a bad cam bearing has been known to cause the melting goo.
Old Mar 21, 2018 | 06:22 PM
Frog Nuts's Avatar
Frog Nuts
This friggin goo,Ive not found anything that cuts it yet..carb cleaner,gas,bitchin..nada.
Scraping/rubbing takes ferever..lol
Well now I guess its time to check what cam and replace the bearings..What needs to be done before,TDC...front jug? etc.
Ive not got the factory service manual yet
Old Mar 21, 2018 | 06:25 PM
98hotrodfatboy's Avatar
98hotrodfatboy
If you need just an ignition sensor plate "Standard Motor Product" makes an MC-SPA-2 and can be found here.
https://www.ebay.com/sch/i.html?_odkw=Standard+Motor+product+mc-1601&_osacat=0&_from=R40&_trksid=p2045573.m570.l13 13.TR0.TRC0.H0.XStandard+Motor+product+mc-spa-2.TRS0&_nkw=Standard+Motor+product+mc-spa-2&_sacat=0
I used the MC-SPA-3 for the 96 up harley's. the only difference is the connectors on the ends of the wires.. I wired it in to my SE programable ignition that I took off my 98 Fatboy and put on my 77 Shovel FXE. Works like a charm...
Oh yea I run the Dyna 2ki on the Fatboy...
Old Mar 21, 2018 | 06:31 PM
Frog Nuts's Avatar
Frog Nuts
https://www.ebay.com/sch/i.html?_odk...spa-2&_sacat=0
Hum, not expensive at all. Mines a 1989...Ill read up on those. Thanks
Shovel eh? Now those are real Harley's..whoops,hope I don't git slapped here fer sayin that
Old Mar 21, 2018 | 06:32 PM
barneyboy's Avatar
barneyboy
Heat gun, or hair dryer should soften it up enough to work it out. Then wait for the manual.
Old Mar 21, 2018 | 08:15 PM
98hotrodfatboy
Nota lot of literature out there on them. The only difference in most of them is the terminal end connectors. They're all Hall effect pickups. The only difference between the Oem and this one is that the OEM has what's called and altitude switch built in that is supposed to kill the ignition if you lay the bike down...
Old Mar 22, 2018 | 10:42 AM
Frog Nuts's Avatar
Frog Nuts
Factory?
Old Mar 22, 2018 | 10:52 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Yep..
That's your ignition control module.
Old Mar 22, 2018 | 11:26 AM
larsfum's Avatar
larsfum
Goo Gone or Goof Off. Comes right off with a bit of rubbing. Doesn't harm the paint. A little Brake Parts Cleaner afterwards and she'll be all clean.
Old Mar 22, 2018 | 11:52 AM
Frog Nuts's Avatar
Frog Nuts
Thank Yall!
Heres what I'm considering as of now,
Amazon Amazon
