Fuel delivery problem
Old Mar 25, 2018 | 12:57 PM
just plain john's Avatar
just plain john
Default Fuel delivery problem
My wife's bike quit last week and I'm diagnosing my trouble today. This bike is carbed. The petcock is vacuum operated. I removed the fuel line to the carb and routed another line to a gas tank. I removed a gas cap, put the selector on main, and pulled a vacuum on the petcock. Nothing. I switched to auxiliary tank and some gas flowed, but soon quit after a cup full or so. I guess the next step is to drain the tank and pull the petcock. Maybe a clogged filter, maybe a failed diaphragm in the petcock. Is my reasoning sound, or am I overlooking something?
Old Mar 25, 2018 | 03:07 PM
WP50's Avatar
WP50
When you pulled the vacuum on it did it hold the vacuum ?? If not that's a problem to address.
Many of us have done away with the vacuum operated pet ****.
You will get a look at what filter it has when you pull the petcock.
Hard to imagine it could be that clogged with getting some fuel out on reserve.
WP
Old Mar 25, 2018 | 03:09 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Pull that stock POS petcock and put on either a Pingle or a Golan.
Old Mar 25, 2018 | 03:34 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Old Mar 25, 2018 | 08:58 PM
just plain john
WP
It'll hold 20#'s for at least three hours
Old Mar 25, 2018 | 10:50 PM
texashillcountry
Dirt don't hurt
There are rubber parts that are in the OEM petcock that when they wear out you have to rebuild/replace the petcock before it will pass fuel no matter how much vacuum you put on it.
Old Mar 25, 2018 | 10:57 PM
NORTY FLATZ's Avatar
NORTY FLATZ
You don't say what year your wife's bike is. If it's a 1996 or before, then there's a recall for that petcock diaphragm. The original diaphragm doesn't like MTBE nor ethanol.
Old Mar 26, 2018 | 04:52 AM
just plain john
Sorry, it's a 99 so it's not included
Old Mar 26, 2018 | 06:45 AM
texashillcountry
Dirt don't hurt
Hey John are you thinking about attending the meet up?
Old Mar 26, 2018 | 12:25 PM
grbrown's Avatar
grbrown
John, if the petcock is original it's almost 20 years old! I'd be inclined to replace it with a non-vacuum type anyway, while checking for other related problems. I have a Pingel, however the older factory stock style of taps are available new for much less.
