swingarm pivot bolt torque ??
Old Mar 28, 2018 | 02:32 PM
evobigape's Avatar
evobigape
Default swingarm pivot bolt torque ??
whats the torque spec for the swingarm pivot bolt for softail 98 i cant find in the book my swingarm is a rolling thunder but i think is the same torque value as a stock one and do i need to put locktite ?? thank guys
Old Mar 28, 2018 | 03:44 PM
Mattbastard's Avatar
Mattbastard
We had a saying back in Northern Wisconsin; just reef on it.
I'd use loctite too.
Old Mar 28, 2018 | 06:31 PM
Uncle G.'s Avatar
Uncle G.
From the 1994 Service Manual-120 to 150 ft.lbs.
Old Mar 28, 2018 | 09:49 PM
98hotrodfatboy's Avatar
98hotrodfatboy
120-150 ft lbs is correct.
Old Mar 28, 2018 | 09:50 PM
98hotrodfatboy
120-150 ft lbs is correct. There should be a star lock washer there, loctite is not necessary...
Old Mar 29, 2018 | 08:11 AM
Tom84FXST's Avatar
Tom84FXST
No bolt on any bike I work gets installed without at least blue...critical or hard to reach bolts get red..whether they need it or not.
Seeing a bolt leaving your bike and bouncing down the road is very unnerving...haven't seen that since I started an "all bolts get loctite" policy.
Old Mar 29, 2018 | 09:17 AM
evobigape's Avatar
evobigape
ho yes i forget to put locktite on my gaz tank bolt last year and is a split tank the tank almost fall on the road imagine so now im a pro locktite user loll
Old Mar 29, 2018 | 11:04 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Each of your tanks has 3 bolts for a total of 6 bolts for your gas tanks.
I've had mine now for 10 years and haven't had a problem with mine, no lock tight used.
However I do have to replace the rubber bushings almost every time I take the tanks off.
Old Mar 29, 2018 | 08:41 PM
98hotrodfatboy
There are many many bolts on our solid mounted Harley's that definitely need Loctite but the pivot bolts on the Softails is not that critical, is all I'm saying. To each their own.......
Old Mar 29, 2018 | 09:25 PM
texashillcountry
Dirt don't hurt
I can think of a bunch of bolts I would rather lose than a pivot bolt.
