Charging System Explanation???
That's why I've always referred to the parts on a Harley separate (stator, rotor, or rectifier) instead of just calling it an alternator.
Everyone went to alternators because the were smaller, lighter, and required no maintenance
According to the dictionary:
alˇterˇnaˇtor
ˈôltərˌnādər
noun
a generator that produces an alternating current.
alˇterˇnaˇtor
ˈôltərˌnādər
noun
What I was making a distinction about is that on a Harley the alternator is 3 separate parts and on a passenger vehicle it's all in 1 unit.
Alternator = alternating current...nothing more, nothing less
Older alternators had the voltage regulator separate...how do you classify them?
On a Harley you don't have to replace all three parts to fix your charging system (usually) however you don't take your car alternator apart when you go to the parts store to get a new one.
Yes I completely agree that both systems work in exactly the same way but replacing the bad parts is done differently.
That's all I'm really saying.
As for older alternators had the voltage regulator separate since I've never messed with one I don't worry about it.
https://www.flickr.com/photos/35351847@N05/3806786407
here
As we all know electrical systems run on smoke because when the smoke leaks out they don't work anymore!!!!
The alternator/dynamo of a motorcycle is far less complicated, smaller in size, cheaper, but technically sucks. Here, a permanent magnet is used which means the output is fixed, and needs to be regulated a different way. The rectifier/regulator does this by burning the remaining amps from the alternator to ground. In other words, the alternator is ALWAYS stressed to max capacity, one of the reasons why they'll go south once in a while.
P = U * I (Power = Voltage * Amps)
If you have a 300 watt alternator, you will need to pull (300 watt / 13 volts) = 23 amps from it, in order to keep the voltage at 13. If the electrical system (ignition, lights etc) only needs 5 amps, the voltage would rise to 60 volts (300 watt / 5 amps) if the regulator didn't come into play. It will burn away (waste) 18 amps to ground in order to keep the voltage at 13.
I've been reading quite some messages from people stating a faulty battery will destroy your stator and I really wonder why, since the alternator is stressed to full capacity anyway, regardless the state of the battery.
Btw, mine burned down yesterday
What burned down???
Charging system or whole bike???????????
