Charging System Explanation???
Old Apr 15, 2018 | 01:10 PM
cskarns's Avatar
cskarns
Default Charging System Explanation???
Could someone explain how the charging system work's on a motorcycle. Is it similar to a car in that the battery starts the car and the charging system runs the electronics or does the battery run the electronics and the charging system just replenish the battery?
Old Apr 15, 2018 | 01:16 PM
MURPHCC1's Avatar
MURPHCC1
Same as a car.....stator and rotor produce AC current........Voltage regulator changes it to DC via diode rectifier and regulates so not to spike anything...........charges battery and runs all electrics.
Old Apr 15, 2018 | 03:45 PM
Yankee Dog's Avatar
Yankee Dog
Throw in some circuit breakers for individual circuits and some switches and that pretty much sums it up.
Remember the rotor (has magnets in it) spins around the stator creating AC (alternating current) and it flows to the voltage regulator that has diodes in it that clip the AC sine wave to make it eventually a flatter more DC (direct current) sine wave (sort of but close enough for this) as well as circuitry to reduce (regulate) the DC voltage to about 13.5 to 14.5 volts DC.
That DC current recharges the battery, powers light, accessories and ignition with the circuits being protected by circuit breakers. YD
Old Apr 15, 2018 | 09:49 PM
cskarns's Avatar
cskarns
Thanks for clearing that up. Was told that it was one way buy one guy and the other by another guy.
Old Apr 15, 2018 | 10:03 PM
Ron750's Avatar
Ron750
If it's the same as a car, why do you need a good battery, and ground for the engine to keep running, even after it has been started?
I had a Vulcan 750 that died if you put the directional on. You could push start it, but it backfired and eventually died. All it needed was a new battery. There was just a thread about a Harley backfiring and lots of posters recommended checking the battery, and connections.
I was just going to do some reading on this, but if anybody could answer it here, I would appreciate it.
Old Apr 15, 2018 | 10:32 PM
Racepres's Avatar
Racepres
^^ The Ignition system is Grounded thru the Engine Cases.. No Ground= no spark
Tho I personally have Never experienced a "miss" due to a Poor Ground..
I do take pretty good care of my Electrical system tho..
Also... the Regulator needs to be Grounded, as it Dumps excess Voltage directly to Ground.. Some automotive systems... and Many Newer Systems Regulate the output of the Alternator with the Regulator... the Evo [and earlier] run the Alternator at Maximum [based on RPM] and simply Shunt excess juice to Ground!!
Just so ya Know..
Old Apr 15, 2018 | 11:45 PM
Prot's Avatar
Prot
This was a lengthy but good discussion about the charging system and battery.
https://www.hdforums.com/forum/showt...1080765&page=1
Old Apr 16, 2018 | 02:32 AM
Ron750's Avatar
Ron750
That was a great thread. I just subscribed to it. A little scary that I have no recollection of reading it! That Harley Davidson is one smart dude.
How did that new battery work out?
Old Apr 16, 2018 | 08:57 AM
Prot's Avatar
Prot
It was, and still is, the best battery I ever bought for my bike.
Old Apr 20, 2018 | 10:32 AM
Tom84FXST's Avatar
Tom84FXST
Regardless of people calling it a rotor/stator...it is an alternator. Alternators unless they are "self exciting" need battery current to charge ...many cars will die if you remove the battery cable while it is running...unlike the old generator vehicles.
