Brake dilemma
Old Apr 28, 2018 | 07:33 PM
flhchaz's Avatar
flhchaz
Default Brake dilemma
Hey all. Trying to wrap up the rebirth of my ‘97 flht. My right front caliper is fubar. I guess the last time I did brakes, I did not have the pins that hold the inner bracket to the outer caliper body lined up when I tightened it and the pin and the female part that the pin goes into are bent way out of shape.
I bought a couple used calipers off eBay and they are totally pitted inside and it looks like there is silicon in them.
So.......I know that people here have upgraded to Twinkie calipers and adapter brackets. Can anyone point me to a thread, or lay some knowledge on me about the Twinkie caliper conversion?
I’m finishing the super e install tomorrow and hope to get it running, all I need to do is get the front brakes sorted and I’ll be back on the EVO!
Old Apr 28, 2018 | 07:56 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I don't know much about twinkies but Performance Machine makes calipers that will bolt right up.
Little pricey though.
Old Apr 28, 2018 | 08:20 PM
flhchaz's Avatar
flhchaz
A little too pricey!!
Old Apr 28, 2018 | 10:44 PM
Beemervet's Avatar
Beemervet
I've got the Twinkie calipers, braided lines, and adapters for the EVO legs. Message me.
Old Apr 29, 2018 | 05:03 AM
misfitJason's Avatar
misfitJason
It's just a simple bikers choice adapter bracket. The downside for you would be you either have to rebuild the Caliper when you get a used one to run dot 5, or you will be needing a compatible brake master cylinder and new line
Old Apr 29, 2018 | 07:15 AM
0maha's Avatar
0maha
That was what steered me away from that approach a few years ago. By the time you get the bracket, an eBay caliper, and the rebuild kit, you're most of the way toward paying for a Wilwood GP310 anyway.
Old Apr 29, 2018 | 07:13 PM
Mchad's Avatar
Mchad
+1 on the Wilwood GP310. Got mine off Amazon and it is such a dramatic improvement over the single piston stock caliper that came on my FXR. Worth every penny of the $240 I paid, and a direct bolt up as well.
Old Apr 29, 2018 | 08:46 PM
flhchaz's Avatar
flhchaz
Thanks for all of the replies, and thanks to Beemervet’s parts stash, I am all set.
Thanks again
Old May 14, 2018 | 06:55 PM
flhchaz's Avatar
flhchaz
[QUOTE=0maha;17316854]That was what steered me away from that approach a few years ago. By the time you get the bracket, an eBay caliper, and the rebuild kit, you're most of the way toward paying for a Wilwood GP310 anyway.[/QUOTE
Omaha, when you installed the gp310’s were you able to use your stock length cable?
langwilliams
EVO
May 7, 2016 06:56 AM
tmilo1000
Apr 21, 2014 02:30 PM
last saint
Jan 3, 2011 08:03 PM
Racer_Rick
Ironhead
May 15, 2009 06:38 PM
67zoomie
Dec 3, 2005 01:20 PM
