Weird timing behavior
That's a harmonic balancer, and combined with a Darkhorse Crankworks balanced crank that bike is mirror smooth on the highway. If you search under my username I created a post on the HD forum about it.
Seriously, I made the assumption that the vacuum at idle was deep enough to trip the VOES. Well, removed it, put my vacuum pump on it and it would pull a little then hit zero in about a quarter second.
I grounded the VOES and BAM, repeated 15 degree marks flashing like clockwork. Idle went to the damn moon too because I had it cranked so high to compensate for the retarded timing.
1994, by the way. I'll update. Thanks y'all.
I grounded the VOES by using a small alligator clip across the two male leads in the deutsch connector. The idle shot up and the timing went dead nuts on 15 degrees. I adjusted the plate to just under 30, right where I want it for my angled dome pistons and 10.5:1 CR. Ordered a 6" VOES online for $45 since NOBODY in San Diego has one. There's on in LA, but I ain't driving all the way up there for something twice the price of buying it online for.
you may even find 32-33 will still be fine at 10.5:1 compression ..
"2000+ rpms area" for full advance to come in.
high idle wont be high enough to find out what your total full advance will be.
Yea, I was looking at ignition curves from Nightrider and 2000 seems to be where full advance hits. I thought it was higher but whatever...
I'm ok for now, until I get the tach installed. I have no idea where my RPM was actually so I may be a bit advanced since right now I'm in the high 20's but probably below 2000.
So I got my primary all buttoned up (Energy One clutch pack with extra disc and heavy spring) and checked timing with VOES grounded one last time making sure I was at full advance. I fired the bike up and cranked the idle up to what I can only assume was around 2K. Spark was right at 28ish. Just to check advance, I upped the revs a bit more and checked again with no change. From this I assume that's full advance.
Also, credit where due, the Harbor Freight dial back timing light works great! I set the dial at 0 degrees and the flash was at 28 degrees. I slowly turned the dial up and when the flash was at TDC the dial said 28 degrees. I like how that works. I can now use the inspection port in the crankcase and use the dial to see where ignition is by looking for the TDC mark and then checking the dial. I just have to remember the induction clamp has an arrow on it that points towards the spark plug. My new Bosch timing light doesn't care which direction it's clamped.
Also, 6 speed TC's only have Loctite on the inner primary bolts, never seen one come loose.
Going forward, now I can use my timing hole plug and the dial back timing light to do all timing. I just hook up the light and turn the dial until I see the TDC mark on the crank, then look at the dial to see my timing.
That S&S crank has a really faint mark for advance, and it's at 35 degrees. Since I'm at 28 that won't work.
