95 evo with 89 primary
Old May 22, 2018 | 01:10 PM
Ed Swinney's Avatar
Ed Swinney
Stage I
Default 95 evo with 89 primary
im attempting to join the 95 evo engine to a 89 primary, wanting to use a 95 clutch assembly. ive run into the jackshaft size issue, and think ive got it ok, are there any other issues i should be looking for?
Old May 22, 2018 | 04:40 PM
Bulpitt's Avatar
Bulpitt
I just went the other way with my 86' EVO. Put a 92 transmission and primary on it with newer style starter etc...The transmission was changed because the tab the starter bolted to was for the Shovel era starter and so was the primary. I say all this because I don't remember when they went from the older starter setup to the newer but I want to say it was in 1990. Make sure the starter shaft will align with the hole in the inner primary & the primary cover.
Old May 23, 2018 | 07:28 AM
Racepres's Avatar
Racepres
Engines are absolutely interchangeable... except Twinky... Even a Shovelhead will go right in...
Need a Shovel top motor mount is all...
Old May 23, 2018 | 09:13 AM
Tom84FXST's Avatar
Tom84FXST
Actually an early twinkie will bolt in with a simple adapter.
https://www.jpcycles.com/product/701...SABEgJU3fD_BwE
Old May 23, 2018 | 01:48 PM
Racepres's Avatar
Racepres
Thanks... Interesting... I would not want to Downgrade... but... it is Interesting being Twinkies are so Cheap!!
jamiefixit
May 29, 2014 04:03 PM
bluharley
EVO
Feb 23, 2014 05:54 AM
wammerjammer
Shovelhead
Sep 3, 2013 08:37 AM
HarleyReece
EVO
11
Aug 23, 2012 02:02 PM
vme2
Sep 7, 2010 07:50 PM
