95 fxdl rear brake caliper/disc hot
Old Jun 7, 2018 | 07:45 AM
xflyer's Avatar
xflyer
Default 95 fxdl rear brake caliper/disc hot
i just replaced the rear tire on my fxdl, local indy who mounted my tire said i should check my rear brake due to bluing on the rotor. and after getting it back together rode 2miles came back very hot. Removed caliper and cleaned piston and seals with dot5. Bled brakes replaced all fluid, and test rode again still warm not as hot. Then tested again w/o using rear brake and was still hot but not terrible. Ive been reading a lot of posts, and most people say the rears will still have some heat no matter what. The pads do look a little uneven like they contact more on the top of the rotor versus the bottom. Any ideas should i replace pads/rotors? No issues with braking pedal is firm, just concerned about the heat and it boiling the fluid.
Old Jun 7, 2018 | 08:39 AM
nibroc's Avatar
nibroc
uneven pads will cause that
Old Jun 7, 2018 | 09:52 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I suggest you rebuild the master cylinder, sometimes the return port gets gummed up and this will cause the pistons to not retract far enough.
Old Jun 7, 2018 | 11:20 AM
KozmoSoftail98's Avatar
KozmoSoftail98
After rebuilding my caliper three times and still getting hot/locked pads, I bought a new master cylinder. That fixed it. I could have rebuilt the master but I was getting too mad to go through another rebuild. I think I spent $60 on DOT 5 through the ordeal.
Old Jun 8, 2018 | 07:30 AM
xflyer's Avatar
xflyer
Thanks to everyone for the replies! i am going to replace the pads and going to take a close look at the master cylinder.
rphillips
Dec 17, 2015 05:38 PM
HamToast
Mar 18, 2015 12:23 AM
vbhousehunter
Wheels/Tires
Nov 4, 2012 08:31 AM
1Digger
Aug 18, 2011 06:23 PM
cooker69
Wheels/Tires
May 18, 2010 12:51 AM
