Microsquirt
Old May 2, 2019 | 06:28 AM
  #31
Mattbastard's Avatar
Mattbastard
Originally Posted by Hackd
Yep. Lot of fun. Unfortunately, I don't have the time to 'play' with it. I'm thinking about putting it on the market:
Before:
And after way too much money:
But back to the OP's question... I looked into the MS system when I was contemplating the EFI engine for the CJ. I liked what I read, but after also looking into the EEC-III Ford system, it was an easier conversion. My 76 CJ5 'thinks' its a 93 Mustang.
I'd really like to do a MS project, just have way too many other things on the burner right now...
Thanks for the info. That's a bad-*** Jeep ya got there.
Oh, and I'm the OP, I've got free reign to derail my own thread.
Old May 2, 2019 | 10:56 AM
  #32
evotrike's Avatar
evotrike
Found the MM EFI easy to reset and get running correctly on my 98 Ultra. No scanalyser, etc. needed. Would not trade it for any carb. This system has an undeserved bad rep, IMO.
Old May 27, 2022 | 09:53 AM
  #33
gl90hog's Avatar
gl90hog
Originally Posted by Dr.Hess
Yeah, I run MegaSquirt on the Sportster. Dr.Linda says it's like riding with an automatic transmission. Just put it in a gear and go. That is, smooth. Go for it.
Hi Dr. Hess
I just installed a microsquirt on my sportster, and it sort of runs, but definitely not as smooth as you say. It's probably a matter of configuration. Would you care to share your VE table? Just for me to understand the broad picture, obviously the absolute values would not suit my needs, but I need to see how it looks like
Thanks!
Old May 27, 2022 | 01:03 PM
  #34
Dr.Hess's Avatar
Dr.Hess
I haven't messed with megasquirt in maybe 15 years now. The biggest thing was to not use the MAP sensor, except for barometric correction. So, only use alpha-n, not speed density. After that, if you "auto tune" with a laptop in a backpack, you should get pretty close. That's about what I did with it.
Here is the last .vex file I could find for it:
EVEME 1.0
UserRev: 1.00
UserComment: Exported from MegaLogViewer
Date: 6-28-2007
Time: 19:57
Page 0
Scale 1.0
VE Table RPM Range [12]
[ 0] = 8
[ 1] = 13
[ 2] = 18
[ 3] = 24
[ 4] = 30
[ 5] = 35
[ 6] = 41
[ 7] = 47
[ 8] = 52
[ 9] = 58
[ 10] = 64
[ 11] = 70
VE Table Load Range (TP ADC) [12]
[ 0] = 60
[ 1] = 70
[ 2] = 75
[ 3] = 85
[ 4] = 95
[ 5] = 110
[ 6] = 120
[ 7] = 130
[ 8] = 150
[ 9] = 170
[ 10] = 190
[ 11] = 235
VE Table [ 12][ 12]
[ 0] [ 1] [ 2] [ 3] [ 4] [ 5] [ 6] [ 7] [ 8] [ 9] [ 10] [ 11]
[ 0] = 21 20 26 24 23 24 24 29 36 45 55 59
[ 1] = 27 32 32 30 31 23 20 21 31 44 55 60
[ 2] = 39 43 38 29 27 23 24 31 40 48 55 60
[ 3] = 43 50 40 37 28 27 29 33 43 48 57 65
[ 4] = 48 53 42 46 46 32 33 36 47 50 55 60
[ 5] = 48 49 45 50 45 40 42 38 41 55 56 62
[ 6] = 48 51 45 48 39 36 43 40 52 61 62 65
[ 7] = 49 51 50 51 44 39 49 48 49 62 62 68
[ 8] = 50 49 50 53 49 46 48 56 62 62 62 68
[ 9] = 49 51 51 49 50 52 52 56 62 62 62 70
[ 10] = 51 52 55 56 53 50 51 54 60 64 67 70
[ 11] = 48 52 53 58 53 49 57 65 68 70 70 75
Old May 27, 2022 | 01:07 PM
  #35
Dr.Hess's Avatar
Dr.Hess
Also, make sure that you have a temp sensor working. I put a thermistor in a ring terminal and put that under the motor mount on the head. Works great. Another thermistor in the air cleaner for IAT. Fiddle with the temp settings to compensate for the larger temp variances that an air cooled motor will have versus a water cooled one.
Old May 27, 2022 | 01:12 PM
  #36
Dr.Hess's Avatar
Dr.Hess
I found a .msq file. I can email it to you if you can convert it to whatever software everyone is using now. Here's the maps:
<constant name="rpmBins1" rows="12" units="RPM">
800
1300
1800
2400
3000
3500
4100
4700
5200
5800
6400
7000
</constant>
<constant name="rpmk1">6000</constant>
<constant name="tpsBins1" rows="12" units="TPS">
50
60
70
75
85
95
110
130
150
180
210
235
</constant>
<constant name="twoStroke1">"Four-stroke"</constant>
<constant cols="12" name="veBins1" rows="12" units="%">
33.0 23.0 20.0 23.0 34.0 45.0 49.0 50.0 48.0 47.0 45.0 44.0
40.0 46.0 32.0 40.0 48.0 47.0 49.0 49.0 47.0 48.0 47.0 45.0
38.0 45.0 37.0 45.0 49.0 47.0 50.0 50.0 47.0 50.0 48.0 47.0
40.0 49.0 53.0 42.0 50.0 53.0 56.0 56.0 53.0 51.0 50.0 48.0
55.0 47.0 59.0 44.0 51.0 54.0 57.0 56.0 54.0 53.0 51.0 50.0
37.0 46.0 61.0 56.0 60.0 63.0 65.0 65.0 63.0 56.0 54.0 51.0
38.0 45.0 63.0 63.0 63.0 66.0 67.0 67.0 66.0 57.0 54.0 53.0
52.0 58.0 60.0 57.0 64.0 67.0 69.0 69.0 60.0 59.0 56.0 54.0
53.0 60.0 52.0 58.0 64.0 69.0 70.0 70.0 62.0 59.0 57.0 56.0
50.0 54.0 58.0 60.0 68.0 69.0 72.0 71.0 69.0 69.0 68.0 65.0
43.0 45.0 57.0 69.0 74.0 79.0 82.0 82.0 79.0 80.0 77.0 75.0
47.0 51.0 65.0 78.0 83.0 87.0 90.0 90.0 87.0 89.0 87.0 84.0
</constant>
Old May 27, 2022 | 02:14 PM
  #37
gl90hog's Avatar
gl90hog
800
1300
1800
2400
3000
3500
4100
4700
5200
5800
6400
7000
</constant>
50
60
70
75
85
95
110
130
150
180
210
235
</constant>
</constant>
Thanks!
If you can email the files to gl.90.hog@gmail.com, I appreciate it!
I installed the temperature sensor already, on a intake manifold bolt, seems to work fine
Old May 27, 2022 | 06:00 PM
  #38
Dr.Hess's Avatar
Dr.Hess
It's on the way. Check your spam folder.
Old May 27, 2022 | 06:06 PM
  #39
Dr.Hess's Avatar
Dr.Hess
Also note that we are running basically a stripped down megasquirt 1 series board. Microsquirt was always "any day now" on the initial release and I just gave up on waiting for it and built this one. But the maps and some of the other settings should get you going.
benihanna_77
EVO
11
Aug 21, 2015 11:50 PM
grahamzies
Jul 9, 2015 02:03 PM
DeraldL
Jan 8, 2013 01:13 PM
petewood70
EVO
19
Jul 1, 2010 06:55 PM
SANDMAN69
Exhaust System Topics
May 6, 2007 03:39 AM
