PLUG FOULING
Old May 1, 2007 | 11:33 PM
SANDMAN69's Avatar
SANDMAN69
Stage IV
Default PLUG FOULING
I'M TOTALLY LOST, I THINK I HAVE CHANGED EVERYTHING EXCEPT ENTERNAL PARTS IN MOTOR, I HAVE A 80 EVO PLUGS STARTED TO FOUL OUT, SO I WENT A STEP HOTTER NO HELP REBUILT CARB(SUPER E)NO HELP, BOUGHT NEW CARB NO HELP REJETTED NEW CARB AS SMALL AS THEY MAKE BOTH THE JETS, CLEANED AIR FILTER, REPLACED ALL MANIFOLDS GASKETS, SO I DECIDED IT MIGHT BE IGNITION SO I REPLACED THE SCREAMING EAGLE FOR THE DUAL FIRE CRANE IGNITION AND CIOL FOR A LOT HOTTER AND BETTER SPARK,AND WIRES SAME PROBLEM, BIKE RUNS GREAT FOR ABOUT 3 MILES THEN STARTS TO STUTTER THEN I PULL THE PLUGS AND THERE FOULED NOT OILY AT ALL. JUST PUFFY BLACK DEPOSIT THAT I CAN BASICALLY JUST WIPE OFF. I HAD THIS BIKE FOR 5 YEARS AND HAD NO PROBLEMS WITH THE CARB OR ANYTHING ELSE. THEN THIS HAPPEND THIS WAS AFTER WINTER COULD I HAVE BAD GAS I DID PUT STABLE IN IT, I DONT KNOW IM JUST SHOOTING AT STRAWS KNOW THX SANDMAN69 [sm=WTFsgign.gif]
Old May 2, 2007 | 12:12 AM
ZD's Avatar
ZD
Default RE: PLUG FOULING
ORIGINAL: SANDMAN69
If you haven't tried fresh fuel, I'd give that a shot next. I had an 80 FLH that needed long-reach plugs. If I put the standard plugs in it, it'd foul 'em in no time at all.I don't remember theChampion number. The engine was stock except for a conversion to no-lead heads.
Good luck
Old May 2, 2007 | 05:04 PM
SANDMAN69's Avatar
SANDMAN69
Stage IV
WELL I TRIED FRESH FUEL AND NEW PLUGS, AND STILL HAVING SAME PROBLEM BLACK SOOTY DEPOSITS ON MY PLUGS. RIGHT KNOW IM RUNNING NGK BPR5ES-11 , BUT IVE TRIED ALL THE PLUGS I CAN THINK OF AND I STILL HAVE THE SAME PROBLEM. JUST SEEMS WIERD ONE DAY RUNNING GREAT AND THE NEXT ALL KINDS OF PROBLEMS.
Old May 2, 2007 | 05:16 PM
ZD's Avatar
ZD
Possibly your coil or ignition is going belly-up. I'd shut off the fuel (assuming it's not FI), pull the plugs, connect the plugs to the wires and make sure the body (steel part) of the plug is making contact with a non-painted surface. Crank the thing over and look at the spark. (Keep your face away from the plug holes so the compression doesn't flick something in your eye)
The spark should be very snappy and blue, firing on the tip of the plug. If the spark is yellow and/or erratic, you've got an ignition problem. (Coil, electronic ignition, etc.)
If the plugs fire down inside between the ceramic insulation and the body of the plug, then the plugs are junk.
Old May 2, 2007 | 11:52 PM
SANDMAN69's Avatar
SANDMAN69
Stage IV
I KNEW HOW TO CHECK FOR SPARK BUT I DIDN'T KNOW ABOUT WHAT THE SPARK SHOULD LOOK LIKE, I'LL TAKE ANOTHER LOOK I DON'T THINK IT IS IGNITION BECAUSE WHEN I STARED HAVING THE PROBLEMS, I STARTED REPLACING THE PARTS DOWN THE LINE, I HAD A SCREAMING EAGLE IGNITION REPLACED IT WITH A CRANE MULTI SPARK, NO FIX, THEN COIL, NO FIX, WIRES, NO FIX, REPLACED THE PLUGS NUMEROUS TIMES, IVE EVEN REPLACED THAT VOES SWITCH EVEN THOUGH I KNEW IT WAS WORKING BECAUSE MY TIMING LIGHT SHOWED IT WAS ADVANCING RIGHT, BUT I WILL CHECK FOR BLUE SPARK I GUESS IT IS POSSIBLE I COULD HAVE GOT A NEW FAULTY COIL EVEN THOUGH I DID DO A OHMS METER TEST ONBOTH COIL'S NEW AND OLD AND THEY SHOWED THE SAME. I APPRECIATE ALL THE HELPI WAS HOPPING MAYBE I MISSED SOMETHING TO LOOK AT THX AGAIN
Old May 3, 2007 | 02:50 AM
mtnlvr's Avatar
mtnlvr
What exactly is the bike doing????
Book says...If a spark plug fouls repeatedly:
1. Incorrect plugs for the kind of service.
2. Piston rings badly worn or broken.
3. Fuel mixture too rich or enrichener left on too long.
4. Valve guides or seals badly worn.
Also:
5. Excessive valve stem-to-guide clearance.
6. Incorrect float height.
Start with the bold entries (easiest to check).
Then do a compression test followed by a leakdown test. This will tell you rings or valve area.
Old May 4, 2007 | 11:09 PM
YankeeBob's Avatar
YankeeBob
Find your caps lock key and use it please (unlock caps)!! It appears you are YELLING!!
Old May 5, 2007 | 04:03 PM
SANDMAN69's Avatar
SANDMAN69
Stage IV
[sm=dontgetit.gif]Lol
Old May 6, 2007 | 03:39 AM
mp's Avatar
mp
Enrichener might need adjustment, carb diaphragm might be torn or pinched. It sounds like something in the carb. Worn jets or needles could be making it run rich too.
radio915
Shovelhead
13
May 27, 2016 10:32 AM
grahamzies
Jul 9, 2015 02:03 PM
98glider
Ironhead
11
Jun 23, 2014 08:22 PM
petewood70
EVO
19
Jul 1, 2010 06:55 PM
wolf1477
Ironhead
27
Jun 3, 2006 12:54 AM
