Played around with it and I got rid of most of the decel popping, but when I try and start it cold it seems to not wanna run even with the enrichner up, I need to throttle it up a little.
You are correct buuuuuuutttt: Turbo Blue 110 contains tetraethyl lead which adds color to a plug and the lost additive, our town has a station that sells it. Downfall, too much of it will lift a tank liner and hard on a O2 sensor if you try a Wego.
Octane booster adds color but purple, still doesn't read easily, Aviation fuel if you have a plane or contacts, still comes back to if you can get real fuel like mentioned. Reading plugs is harder than putting a wet noodle in a wildcats a$$ with today's oxygen rich fuel but older bikers still want to rely on plug reading, creatures of habit and those wildcats do get pissed off too.
