fxrs kick stand
Old Jun 25, 2007 | 04:21 PM
lowglide's Avatar
lowglide
Default fxrs kick stand
1984 fxrs ... kick stand is very wobbley... end of kickstand hits the chain when kisckstand is in raised position ...replaced spring.. same thing .. any suggestions???
Old Jun 25, 2007 | 07:01 PM
BadLiver's Avatar
BadLiver
Stage II
Default RE: fxrs kick stand
Move your kickstand. They make a replacement kickstand that mounts to the swingarm pivot point on your FXR that looks and performs killer. It prevents it from dragging in deep corners too. You can find it in the drag specialties big book to buy. The first one I saw, the guy had just made a kickstand plate and bolted it in place and attached his kickstand. I will try to give more info and possibly a pic later.
Old Jun 26, 2007 | 03:39 PM
lowglide88's Avatar
lowglide88
I have an 88' fxrs..Ihad the same issue...my problem was the spring/pin but also the the spot on the frame where the kick stand locks into,when extended out, was worn..I had to reinforce the tab area by welding it up and grinding to fit..not a big deal if you knowhow to weld or know someone who can...have to take the inner primary off though.
Old Jun 26, 2007 | 05:56 PM
lowglide's Avatar
lowglide
thanks for the info guys............ i cant believe you have to dismantle the whole left side of the bike just to do this... that really sucks!!!! well thanks i will see what i can do .....dpnt really want to use the bolt on side stand type ...
crcraig
May 31, 2021 05:54 PM
fenwick
Sep 8, 2014 09:55 PM
WVICEMAN
EVO
Aug 20, 2014 10:03 PM
jeramy
Jun 30, 2007 01:23 AM
robbinson
Nov 6, 2006 12:38 PM
