"death wobble" - 96 wide glide
Old Jul 1, 2018 | 09:55 PM
domer94's Avatar
domer94
Default "death wobble" - 96 wide glide
I cant get rid of the death wobble at higher speeds that comes in around sweeping turns. bike had stock front end , fork oil and seals replaced, rear shocks were lowered an inch nothing crazy with a spacer kit. I have 20" apes , new wheels and tires which were balanced.i also had the triple tree bearings checked. I still get some frightening wallow / wobble which makes me have to back off the throttle to get out of. nybody know the cure for this? I checked tire pressures as well. ive had a springer with tall apes and rear slammes as well , never had this issue.
Old Jul 1, 2018 | 11:02 PM
mmesa005's Avatar
mmesa005
Something else to check https://www.hdforums.com/forum/dyna-...ble-cured.html
Old Jul 2, 2018 | 04:51 AM
RANGER73's Avatar
RANGER73
Wheel bearings?
Old Jul 2, 2018 | 06:37 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Does it feel like the bike wants to stand up in the corner? If so I believe this is more related to rear wheel alignment. Most known for Softail models but my 77 FXE does it as well around 70 mph..
Old Jul 2, 2018 | 06:42 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Have you checked wheel alignment?
What tires are you running?
When you say you checked the neck bearings what do you mean? Did you only check fallaway or what?
As mentioned above have you checked your wheel bearings?
Have you checked end play on both wheels?
Old Jul 2, 2018 | 07:02 AM
Architect's Avatar
Architect
I had a bad wobble on my Shovel, checked all the usual things, couldn't make it go away. Talked to tire manufacturer, they asked me to check the tire for round!?!? Well it was a manufacturer defect and my tire was a 1/4" out on one side of the wheel. They gave me a new one, and all is well now. Just a suggestion for something else to check.
Old Jul 2, 2018 | 07:03 AM
bagga's Avatar
bagga
check for loose rear spokes.
Old Jul 2, 2018 | 07:17 AM
Hackd's Avatar
Hackd
Assuming all the above check out, you might consider going with a Carlini Torque Arm. Dyna's have been known to 'flex' quite a bit. Another alternative is the aforementioned sway kit, and a rebuilding of the swing arm bushings.
Old Jul 2, 2018 | 08:48 AM
domer94's Avatar
domer94
jeez... all good suggestion,\.
when I bought the bike, I changed all motor mounts with oem as they were all shot. I replaced both front and rear wheels (with new hubs installed) with new oem spec spokes / oem size tires. I didn't cheap out on the tires Dunlop up front / bridgestone in rear. the wheels were balanced and trued by a shop before I put them on. thought I had rear wheel out of alignment and had it checked again. you can see the wheel turning true. everything seemed tight , no play etc
as to if it wants to stand up , I would just say it just starts an oscilating type movement in the bars during higher speed 68-75mph about wide curves which can only be reduced with slowing down. seemed to be more in line with the thread that mentioned the v-tech motor mount
Old Jul 2, 2018 | 09:32 AM
Tom84FXST's Avatar
Tom84FXST
Did you replace the rubber bushings in the swing arm?
Those can cause wobbles on sweeping turns
