Fat Cat vs. Boarzilla
Old Nov 8, 2023 | 02:34 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I would think for an 80-in motor the fat cat would be better. Scott at Hillside cycles even once told me the Borzilla is really only for 124 cube inches and above..
Old Nov 8, 2023 | 05:42 PM
Rusty Springs's Avatar
Rusty Springs
Originally Posted by jcsurf
Thanks for all your replies guys. Still reading up on what "too much pipe" is.
Here's my understanding. If we flow the same volume of air (or fluid) through a large pipe and a small pipe the velocity will be higher through the small pipe. There's a sweet spot between a small pipe being too restrictive and a large pipe slowing the velocity too much. There's just as much water flowing through the narrow part of the river as the wide part.
Old Nov 9, 2023 | 05:27 PM
Racepres's Avatar
Racepres
nd e
Hinting at the "Why" ... custom...one off pipes, are the Best for Highest performance..
BTW the Wider the RPM band being Used...the more Complicated the Exhaust!! There is more than one reason that the crossover Headpipes on a "warmed" 80 incher work so damn good....accross the RPM Range.
Yes, Velocity (at the Port) is Where it's At!!!! For Fill.
jblackwell467
Exhaust System Topics
Apr 7, 2018 03:40 PM
D4691
2014-2024 Touring Models
29
Feb 17, 2015 05:11 PM
Bad Disposition
Oct 19, 2010 09:40 PM
hydrolock43
Aug 17, 2010 11:59 PM
norfolk88
Aug 2, 2007 05:10 PM
