'98 Springer Softail passing lamps wiring
Old Aug 3, 2018 | 08:22 PM
Beemervet's Avatar
Beemervet
Default '98 Springer Softail passing lamps wiring
Ran across passing lamps with bracket and switch for the '98 FXSTS. I believe the kit is 68248-98, but I bought it from the second owner. Being a wiring retard, I'm hoping someone has the paperwork that comes with the kit, you know, "Installation for Dummies". Everything is bolted up. Anyone?
Old Aug 3, 2018 | 08:28 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Not sure how it works on your springer but on my heritage I found a constant hot wire on my ignition switch (wire only hot when switch is on) and wired it to the toggle switch that operates the passing lamps.
That way the passing lamps can work when the high beam is on.
Old Aug 3, 2018 | 09:53 PM
mmesa005's Avatar
mmesa005
Hope these help?
File Type: pdf
Old Aug 3, 2018 | 09:54 PM
Beemervet's Avatar
Beemervet
I've got one wire coming from each lamp (gray/black), and two coming from the switch. That's it.
Old Aug 3, 2018 | 09:55 PM
Beemervet's Avatar
Beemervet
Originally Posted by mmesa005
Hope these help?
Thanks
checking them out now.
Old Aug 3, 2018 | 10:06 PM
Beemervet's Avatar
Beemervet
That's the one I was looking for. I have the wiring in my FSM.
This place is a great resource.
Thanks
Volbob
Electrical/Lighting/Alarm
May 16, 2016 03:10 PM
bobbyw47
Apr 27, 2011 12:38 PM
AndrewMichaelZ
Mar 7, 2011 08:37 PM
Coaster
May 14, 2006 07:50 PM
rbcss
Dec 15, 2005 09:00 PM
