1997 flhtc
Old Aug 7, 2018 | 09:48 PM
Mike Simeone's Avatar
Mike Simeone
Default 1997 flhtc
I’m getting backfire or popping at the carb at times when revving. Any suggestions on how to fix would be appreciated.
Old Aug 7, 2018 | 10:39 PM
mmesa005's Avatar
mmesa005
That is indicating a lean condition which may be caused by leaking intake manifold seals, accelerator pump issues. When replacing the intake manifold seals it would be a good time to do a rebuild kit and check the float level for proper setting. How are the spark plugs and wires?
More info and parts here: https://cv-performance.com/
Old Aug 8, 2018 | 05:43 AM
Mike Simeone
The plug wires are new.
Old Aug 8, 2018 | 07:37 AM
Tom84FXST's Avatar
Tom84FXST
Popping out the carb is usually a vacuum leak...could be the intake...could be the hoses routed to the VOES or petcock...or either could have a bad diaphragm.
Old Aug 8, 2018 | 08:33 AM
Mike Simeone
I am going to get a CV rebuild kit as suggested. The bike had beef sitting for 8yrs prior to restoring last year. I never touched the carb other than new air intake. Seals should probably be replaced. I appreciate the input.
fxrglide91
Shovelhead
14
Sep 7, 2019 09:28 PM
Dudepants
Jun 27, 2018 09:52 AM
DFD
Apr 10, 2018 11:38 AM
Meoff
Carburetor Related
Mar 19, 2018 08:27 PM
BruceT1971
Feb 14, 2018 08:49 AM
