Burning oil
Old Aug 24, 2018 | 06:10 PM
Shem77's Avatar
Shem77
Default Burning oil
Hi yall, so recap is 97 FLHR Road King, carb. I have posted inquiry before on why my right side pipe has wisps of smoke coming out after warm up during idle. I have tried the spraying into exhaust manifold to detect leaks but dont get anything from that. It also runs very well so im not thinking its a rich thing. I do happen to go through alot of oil though and was wondering if its burning it. I have no detectable leaks but have had to put a quart in off and on in the last 3000 miles. Is that normal?
I have 55,555 miles so not sure if rings, gaskets etc. might need to be replaced?
thanks for your offerings!
Old Aug 24, 2018 | 06:27 PM
Yankee Dog's Avatar
Yankee Dog
Time for a compression check. Do you have the factory service manual? YD
Old Aug 24, 2018 | 06:38 PM
Daedalus's Avatar
Daedalus
I'd say a quart per 3000 miles for a big twin isn't all that much, specially when its pushed to its limits. Mine uses less, but I ride it like a turtle on roofies.
"wisps of smoke coming out after warm up during idle" suggest a valve seal has gone south?
Old Aug 24, 2018 | 07:13 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I can't wait to use that phrase on somebody!!!!!!!!!!!!
Old Aug 24, 2018 | 07:21 PM
Shem77's Avatar
Shem77
Well i do ride it pretty hard sometimes. I dont know, I do have a full service manual and am going to borrow a compression tester
Old Aug 25, 2018 | 09:10 AM
98hotrodfatboy's Avatar
98hotrodfatboy
A leak down would be a more sufficient test..
Old Aug 25, 2018 | 11:12 AM
splattttttt's Avatar
splattttttt
I ride the motor on mah twink hard. Usually avg 4k on the freeway
drag starts off stops and use AMSoil
Usually have to add 1.5 wt’s every 5k mi
no wisps of smoke tho
Erilflynn
Milwaukee Eight (M8)
29
Jun 11, 2019 11:18 AM
brandss
Aug 28, 2017 02:15 PM
Runner58
Aug 17, 2014 06:14 PM
stevemaman
Jun 19, 2012 07:11 AM
cowentz
Oil Archive (no new posts)
Sep 11, 2007 02:56 PM
