Front brake light switch
Old Aug 25, 2018 | 09:30 AM
Mike Simeone's Avatar
Mike Simeone
Default Front brake light switch
1997 FLHTC
run/off switch went bad. Took rhs controls off to bypass until I get a new switch. While apart I turned power on to check other switches. I noticed front brake light on. I depressed the switch and it goes off. In other words it’s backwards. Tail light should be lit when depressed, not off as it is doing. Any help? Thoughts?
Old Aug 25, 2018 | 10:07 AM
Dr.Hess's Avatar
Dr.Hess
Put it back together and try it.
Old Aug 25, 2018 | 11:32 AM
yellowstone kelly's Avatar
yellowstone kelly
For what it's worth, my '82 Sportster front brake switch is exactly like that---backwards from what you'd think it should be. It's a "normally closed" switch.
With the brake lever at rest, the switch button is pushed in and the brake light is off. Pull the lever, and the switch button is no longer depressed, and the brake light comes on.
Old Aug 25, 2018 | 12:18 PM
Mike Simeone
Yellowstone Kelly, after toiling over this for a couple hours, it is like you said,normally closed. when back together properly the brake lever has a tab that holds switch closed...trouble now is I cannot get it back together properly! What a pain! The wiring bundle to the switches prevents it from seating on bar as it should....whats the trick??? of course it's a beautiful sunny day!
Old Aug 26, 2018 | 07:06 AM
splattttttt's Avatar
splattttttt
Al I know from faulty front brake light switch is that it makes the ECM alc like a total useless piece of crap. My story... You may have read my post about my bike having some throttle issue where on initial opening would cause the engine to bog and how at highway speeds the check engine light would come on?
This has been going on for three years.
New switch. Priblem solved. ****in poor design!
Old Aug 26, 2018 | 08:09 AM
barneyboy's Avatar
barneyboy
If you are not aware of this, the disassembly/assembly procedure involves placing a shim at the front of the lever. This will prevent damage to the rubber boot on the switch during disassembly/assembly.
As for the wires. There really is no trick. They were in there before disassembly. Take your time, and get them nestled in. Be careful to avoid pinching wires between the switch housing halves.
Old Aug 26, 2018 | 08:46 AM
WP50's Avatar
WP50
Unless you have done it few times it can be a PIA.
Just slow down and take your time. The 2 halfs don't always appear to line up perfectly until you get the screws started and begin to tighten them.
The trick is Not to have any wires pinched in there.
WP
Old Aug 26, 2018 | 08:52 AM
Mike Simeone
Poor design is right. I did get it back together, hit turn signal and blew fuse. Try try again
dmcclain
Aug 12, 2019 10:26 AM
Bluraven
Jul 4, 2015 12:21 AM
rideamap
Electrical/Lighting/Alarm
Sep 16, 2014 01:00 PM
tidefan60
Aug 7, 2010 09:48 AM
pistole
EVO
Feb 8, 2010 06:20 AM
