1992 Fat Boy - Question #:3 - Factory Tachometer
Old Aug 30, 2018 | 06:35 PM
Chrisannagenna's Avatar
Chrisannagenna
Default 1992 Fat Boy - Question #:3 - Factory Tachometer
Does anyone here have a factory pic of a '92 (or close to it) Fatboy Tachometer? I've searched the Internet and couldn't really find much out there. I've attached an E-Bay link below with what seems to be the correct era tachometer:
https://www.ebay.com/itm/HARLEY-DAVI...y/302753650872
The other questions would be - Would this be mounted on the handlebars, and what type of mounting bracket would be used based on the holes in the current mounting bracket on this actual tach? Wanted to make sure this one would work before pulling the trigger on it.
Thanks
Old Aug 31, 2018 | 10:00 AM
Riverside Joe's Avatar
Riverside Joe
If I remember right, Fat-Boys did not have tachs. You can install a tach, but you would need to modify the tins on the handlebar clamp to install that particular bracket, then connect and route the wires accordingly. I have that set-up on my FXWG. My front-end lacks the tins, and I run drag-bars, so it was an easy install. My top handlebar clamp forward bolts fit perfectly with the lower most bolt holes on the hooded tach bracket (4.25" eye-hole to eye-hole). Anything can be done (chopped) depending on how you want your ride to look.------------RJ
Edit: Just saw the pix on your ride. You would need to get pulled-back risers, and drag-bars to use that specific bracket/tach set-up. Another bracket may be out there that you could use, but if you were to use that e-bay set-up, you would need risers to mount that tach bracket.
Old Aug 31, 2018 | 12:37 PM
Chrisannagenna
Joe: Thanks for the reply. Do you have any pics of your set-up? Bear with me, as I am a newbee, but needed more clarification on "risers to mount the tach bracket".
Old Sep 4, 2018 | 01:25 PM
Riverside Joe
I'll try to upload a couple pictures.
Last edited by Riverside Joe; Sep 4, 2018 at 01:34 PM. Reason: Pictures did not upload
Old Sep 4, 2018 | 07:22 PM
98hotrodfatboy's Avatar
98hotrodfatboy
They're getting harder to find.. I have 2 dead ones. They both need a new potentiometer.. they are 2 5/8". Called a mini tach.. usually they mount to the 2 upper bolts on the bar clamp or you get the entire upper clamp ....
Old Sep 5, 2018 | 09:43 AM
Chrisannagenna
Yep, that is the one (or very similar) I saw out there on E-Bay. I would just need to try and find the mounting bracket that goes on the handlebars. Anyone have a part number for the mounting bracket?
Old Sep 5, 2018 | 11:15 AM
98hotrodfatboy
69277-05 will fit 96 up.. tons of em on eBay...
Old Sep 5, 2018 | 11:24 AM
Chrisannagenna
Sorry, to clarify, mine is a '92. Not sure if you have a part number for that one as well.
Old Sep 5, 2018 | 02:53 PM
98hotrodfatboy
A 92, 98 and a 2000 Fatboy all have the same part number for the top clamp so I think the number I quoted earlier is the proper one...
Old Sep 9, 2018 | 05:36 PM
Uncle G.'s Avatar
Uncle G.
The difference between your ‘92 and “‘96-up” is in the electrical connectors. Your ‘92 uses Amp/Molex connectors and ‘96 and later uses Deutsch connectors.
With th a bit of work and a mating connector half, you can adapt a later tach.
