Ignition pickup sensor - 91 Flhtc
Old Oct 16, 2018 | 07:51 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Hey Man
THIS:
needs to be replaced with THIS.
This would be a better choice IMO.
Amazon Amazon
Old Oct 17, 2018 | 03:46 AM
lillemann's Avatar
lillemann
THIS:
Yupp, l know. Mine look's almoust as #1 pic.
Old Oct 17, 2018 | 03:55 AM
grbrown's Avatar
grbrown
Wink
Lots of us have been there! The replacement looks similar yet different, because I suspect they have used a better potting compound which is more durable than the melting variety.
There is a good reason for replacing your entire ignition system with the Dynatek 2000i. The stock ignition module uses advance curves designed to meet EPA regulations, not optimum ones. If you swap over to a Dynatek you should enjoy improved performance and general ride quality, while replacing your old pickup.
Old Oct 17, 2018 | 04:18 AM
lillemann's Avatar
lillemann
Originally Posted by texashillcountry
Surtenly is, have looked at this and think l'am gong for this or another brand. Haven't decided for the one or another, check around first. Thank's for the tip.
Per-Řivind
Old Oct 17, 2018 | 07:01 AM
texashillcountry
Dirt don't hurt
Per-Řivind
Dynatek, Ultima, and Twin Tec are the only ones that are worth a damn the rest are junk.
The Ultima is a Chinese knock off of the Dynatek and is*supposed to be a good unit but I buy American where I can.
Old Oct 17, 2018 | 07:08 AM
Hey Man's Avatar
Hey Man
Yeah, but $42.00 kicks $183.07's *** all day long.
Old Oct 17, 2018 | 07:15 AM
grbrown's Avatar
grbrown
Wink
Actually the reverse is true, as I explain above! Aftermarket gives us better advance curves than the stock module. A cheap tune-up!
Old Oct 17, 2018 | 12:28 PM
lillemann's Avatar
lillemann
I have seen the new one, and they seems to be better than stock ones.
I have the Dyna ignition modul, but have too get that checked out if It's broken, and makes the problem l have.
Old Oct 17, 2018 | 12:32 PM
lillemann's Avatar
lillemann
A friend bought the Ultima couple years ago and did what it supposed to do. Easy install and a cheap solution.
Old Oct 17, 2018 | 12:57 PM
lillemann's Avatar
lillemann
​​​​​​​Yeah it's a cheaper fix up, but you don't have the opportunity to tune up if you have or is going to change cam/intake, different muffler etc.
