Ignition
Old Nov 6, 2018 | 09:39 AM
user 47363638's Avatar
user 47363638
Default Ignition
looking to change my ignition, right now I am running the original one. I had some engine work done and was told I would benefit more with a new ignition, I have a Revolution Performance 85” piston and cylinders 10.5:1 with ported and polished heads and a Tman 590 cam. My question is, what is a good ignition and do I need to mess with the timing, what I am really looking for is a simple plug and play.
Old Nov 6, 2018 | 09:42 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Numa Albornoz
looking to change my ignition, right now I am running the original one. I had some engine work done and was told I would benefit more with a new ignition, I have a Revolution Performance 85” piston and cylinders 10.5:1 with ported and polished heads and a Tman 590 cam. My question is, what is a good ignition and do I need to mess with the timing, what I am really looking for is a simple pug and play.
Dynatek 2000p
What year is your bike?
I ask because depending on the year you need either a 7 pin or 8 pin connector.
Old Nov 6, 2018 | 09:59 AM
user 47363638
Originally Posted by texashillcountry
Dynatek 2000p
‘97 fxdl.
Old Nov 6, 2018 | 10:03 AM
texashillcountry
Dirt don't hurt
‘97 fxdl.
I believe that's an 8 pin connector.
It's easy enough to check. Simply unplug your current ignition module and count the pins.
Old Nov 6, 2018 | 11:52 AM
Racepres's Avatar
Racepres
The Dynatech is a good choice... I do Not recommend Singlefire unless you have dual plugs... but, I do Not like to spend $$ unnecessarily!!!
with single plug heads Singlefire is just a Buzzword... for the Cool kids... not any benefit that can be Proven... BTDT
Willing to look at real proof otherwise... Not a Dyno either thanks... Time slip will work tho...
Old Nov 6, 2018 | 07:43 PM
Kingglide549's Avatar
Kingglide549
A lot of it depends on the other mods.
A proper squish is key to getting the ping to go away, and max pwr
I get away with over 11 to 1 CR double plug / Daytona TT
http://floheadworks.com/Articles/Detonation.htm
https://www.bikesmedia.in/reviews/wh...e-engines.html
There is this and a 1000 other little tricks to truly get performance .
Old Nov 7, 2018 | 04:35 AM
grbrown's Avatar
grbrown
Wink
A problem with the stock ignition module is that the timing curves are compromised, to help meet EPA specs, so changing to an aftermarket module is a good idea, even for a stock bike. The Dynatek Dyna 2000 (note correct spelling!) has a choice of advance curves, which will give improved running over stock, also provide a more suitable curve for your mods. Check their website. I used a Crane for many years, which had similar benefits.
Old Nov 7, 2018 | 05:10 AM
Kingglide549
The only aftermarket I have worked with is Daytona .
It is quite simple to work with and offers a LOT of options.
PLUS
If you have a question the guys in Florida will answer the phone and speak in real english to help you out.
That is a nice option to have also
Old Nov 7, 2018 | 05:51 AM
98hotrodfatboy's Avatar
98hotrodfatboy
97 has Duetch 8 pin connector but that won't matter if you go with the Dynatek D2ki.. Its all in the nose cone as well as the Ultima...
Old Nov 12, 2018 | 03:43 PM
user 47363638
What’s the difference between the dynamic 2000 and 2000p
