VOES vacuum line
Old Nov 11, 2018 | 05:48 AM
user 47363638's Avatar
user 47363638
Default VOES vacuum line
I just had my gas tank changed and it has an aftermarket petcock without a fitting for the other end of the VOES vacuum line, it’s been plugged and runs fine, does anyone know if that will affect the VOES itself.
Old Nov 11, 2018 | 06:45 AM
0maha's Avatar
0maha
As long as the now-unused line is plugged off, you're fine.
Old Nov 11, 2018 | 07:02 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
^^^This^^^
That said I'd replace the vacuum line with a singe hose going straight from the intake to the VOES.
Doing so will eliminate several possible points of failure (the T junction and the plug for the petcock) not to mention giving you a nice new line instead of the however many year old hose that is on there now.
Old Nov 11, 2018 | 08:31 AM
grbrown's Avatar
grbrown
Thumbs up
Originally your bike had a T-piece in the VOES hose, with links from the inlet manifold to the gas-tap and the VOES itself. Your 'new' tap removes a renowned unreliable thing, so as suggested above, simply use a single length of hose from manifold to VOES and dispense with the T-piece.
Neil
Apr 30, 2013 03:15 PM
taconite
Mar 2, 2013 06:27 PM
halmc
EVO
Mar 17, 2010 04:32 PM
99Sportster
Jul 1, 2009 06:20 PM
Roadkingfatboy
May 8, 2009 09:40 PM
