Base gaskets leaks
Old Dec 8, 2018 | 07:44 PM
dubepj's Avatar
dubepj
Default Base gaskets leaks
Just acquired a 1985 Wide glide. I think I have all the Trany and primary oil leaks sorted out now. So now I am thinking about the engine. Had several evo bikes before including a 1992 FLHS that had base gaskets leak. Were the early evos also prone to base gasket leaks??? Or were the early ones less prone to that issue?? Thanks.
Old Dec 8, 2018 | 08:00 PM
Dr.Hess's Avatar
Dr.Hess
Yeah, they do that.
Old Dec 8, 2018 | 08:01 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
A buddy's E-'85 was very prone to base gasket leaks until I helped him install some Cometic SLS base gaskets.
Old Dec 9, 2018 | 04:34 AM
Kingglide549's Avatar
Kingglide549
The AL cylinders move.
Warms ups are important.
Check the base of cylinders and spigot holes for flatness.
Probably they might maybe have dimpled after all these years.
My cure ? Cast iron cylinders!
They dont move and seal everything better.
New studs as the elasticity are probably dead in the 30-year-old crap. (deck ht and squish become one less subtraction)
A Quality gasket sealer like Yammabond .
If Cast Iron is used you do not even need a gasket, just a sealer.
Old Dec 9, 2018 | 04:58 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I would much prefer to just use a gasket than a sealer.
Old Dec 9, 2018 | 05:04 AM
Kingglide549
You cant use just a sealer with al jugs .
Old Dec 9, 2018 | 08:38 AM
Racepres's Avatar
Racepres
Can, but, won't work worth a ****.. Folks need to learn the Warm up of the Sandwich...
Old Dec 9, 2018 | 09:04 AM
Kingglide549
I stumbled onto Axtell stuff ,I knew he existed forever -But I was a bit hesitant about the cast iron jugs .
Turns out, it was the best mistake I have ever made with the EVO.
I will never go back to rubber cylinders for this application.
Old Dec 9, 2018 | 09:12 AM
Uncle Larry's Avatar
Uncle Larry
How many times this has been posted over the years ... It's an innate part of owning an EVO
Old Dec 9, 2018 | 09:34 AM
Kingglide549
Maybe for the new guys, they need info too.
