Are all FXR frames the same?
Old Feb 17, 2019 | 12:38 PM
Greezey Rider's Avatar
Greezey Rider
I'll take a pic and get back to you..
Old Feb 18, 2019 | 07:31 AM
splattttttt's Avatar
splattttttt
ABS doesn’t help you stop any quicker. Just helps avoid wheel lock.
In many cases, normal hydrolic brakes stop faster if used correctly
Old Feb 18, 2019 | 08:20 AM
Mchad's Avatar
Mchad
Yep, I’m well aware of that. My point is I want to avoid that potential wheel lock. Thanks.
Old Feb 18, 2019 | 10:28 AM
splattttttt
They’re handy on wet surfaces when on a bike
Old Feb 25, 2019 | 07:52 AM
Racepres's Avatar
Racepres
BTW
there is a difference... changed ??? IDK when... but the Brakes are mounted differently on the '82, from the '94... all I know about it..Later than regular production???? No idea..
Old Feb 25, 2019 | 08:03 AM
Greezey Rider
Originally Posted by Racepres
BTW
The frame is the same....Brakes are different but all year work on all years.
Old Feb 25, 2019 | 09:02 AM
Racepres's Avatar
Racepres
No... the bracket that holds the master cylinder is different... 1982 to 1994... I just do Not know when the change came... maybe like most other changes... about 1984???
The frames are [other than that weldment]... the same... excepting ..as stated... the early ones did Not have the Frame mounts [weldment threaded bungs] for the frame mounted fairing
There is a 1983, and a 1994 in the shop right now... when [IF] it warms a bit I can get a picture...
Old Feb 25, 2019 | 11:24 AM
Dehammer's Avatar
Dehammer
I have two 1991 FXRs and one has a zerk fitting in the neck, the other does not.
Old Feb 25, 2019 | 12:09 PM
Racepres's Avatar
Racepres
And... why would you want one??
how much grease you think it would take to completely fill the frame neck, such that grease would actually reach the neck bearings????
Plug the zerk one and do it Right!!!!
Old Feb 25, 2019 | 03:13 PM
splattttttt
Okay, I’ll bite... Grease fittings inthe steering nexk.
why are they there?
I guessing older bearings needed them? Or is it a way to avoid corrosion?
