1987 & later frames have an additional location to mount the rear shocks more forward on the top. The old mounting location is there for the FXRT & FXRP models that kept the more straight up & down shock angle of the earlier bikes. It's not a big deal to drill a couple holes & weld in sleeves to give the earlier frames this option.
I thought they had those holes there and just not used.
BTDT.... The Frame is Identical... the [fender] Struts determine mounting... tho the Fenders are Not all drilled for either...
correct, the frame rails have both mounting position holes. The fender struts that go over the rails only have one mounting hole position and determine shock angle. I have some Arlen Ness struts that were for the regular FXR (more forward angle) position that I drilled the RT/RP hole positions into and had a friend weld up the old holes and re powder coated them. You cant tell the and cost me about $20 in beer.
