Driving lights?
Old Mar 27, 2019 | 04:48 AM
simple softail's Avatar
simple softail
Default Driving lights?
I have a 96 heritage and would like to know if I could hook my driving lights up to stay on when headlight is on bright?
If so could someone please explain the process?
Old Mar 27, 2019 | 04:49 AM
RANGER73's Avatar
RANGER73
There's a premade relay kit you can buy or you can make one yourself.
Old Mar 27, 2019 | 04:51 AM
simple softail
Thanks for the quick response. I'll look into that.
Old Mar 27, 2019 | 05:53 AM
grbrown's Avatar
grbrown
Red face
Your question has been asked many times before and the solution has also been posted, so the answer is somewhere out there, around HDF! The challenge is finding it, unless some kind soul calls by and provides a link or tells us all once again. Hopefully that will happen before too long.....
Old Mar 27, 2019 | 06:09 AM
simple softail
I really thought that it would have been, being as it is a 96 model but my ability to search these forums is challenging at best plus the devices I use are not the best.
Just hoping someone has a little in-depth information
Found a kit on the HD website but instructions for my model were vague at best.
Old Mar 27, 2019 | 06:15 AM
grbrown's Avatar
grbrown
Red face
Even the more experienced ones of us have problems with using 'search', hence my hope that someone who knows will call by soon! On recent canbus bikes it is as simple as getting a dealer to plug his computer in and press a few keys - doesn't involve any wiring. The wiring on our older bikes is quite simple, so just hang in there for a while!
FreedomRider's Avatar
FreedomRider
here is a diagram to how to do the change …
Old Mar 27, 2019 | 08:09 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The simplest solution is to disconnect the existing hot wire to the driving lamp switch and wire in a constant hot that is controlled by the ignition switch.
Did that to my Heritage around 10 years ago and still works fine.
Old Mar 28, 2019 | 09:13 AM
kfelt's Avatar
kfelt
1987 Heritage. Bought factory spot light kit. Disregarded instructions and just poked a tiny hole in the rubber grommet where wires go into headlight shell. Ran wire from spots into shell and spliced onto high beam wire. High beam and spots come on at the same time when switched to high beam. Been that way for 31 years. Don't know if yours is the same.
amkaos
Nov 1, 2014 09:24 PM
karz10
Sep 17, 2012 11:23 AM
bear68
Electrical/Lighting/Alarm
Apr 3, 2010 06:17 PM
AwfHand
Jan 14, 2008 11:51 AM
rkh
Sep 7, 2007 10:25 AM
