Wiring harness help
Old Mar 27, 2019 | 07:50 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Default Wiring harness help
Can anybody point me in the direction to get a main wiring harness for an 86 softail part number 70216-86?
The oldest I can find is for a 87 softail.
When did the MOCO move the starter solenoid from the primary to the starter motor?
Correction the part number is 70216-85 not -86.
Old Mar 27, 2019 | 09:05 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
`89 was first year of the modern starter configuration (solenoid mounted on starter).
As long as you use a harness for `90 or earlier I think you will be ok, `91 is when the turn signal module came into the mix, which would make it a little more difficult to adapt.
It`s hard to compare the wiring harnesses by looking at the diagrams, `86 and earlier were drawn using the old method...
Have you considered an aftermarket harness, such as the Ultima (I have no experience with them) ?
Old Mar 27, 2019 | 10:58 AM
texashillcountry
Dirt don't hurt
Thanks for the information Dan!!!!!!!!!!!!!!
So if I'm understanding you right I can use any harness '88 or older correct?
Old Mar 27, 2019 | 12:32 PM
grbrown's Avatar
grbrown
A further suggestion, following on from Dan's, is to consider the Moto Gadget m-unit wiring system. A pal rewired his 1990 Glide using one. There are other brands doing a similar job, which simplifies rewiring by using a centralised device.
Old Mar 28, 2019 | 07:44 AM
Dan89FLSTC's Avatar
Dan89FLSTC
I haven`t worked on anything older than `88 (as far as Softails go), sorry, I jumped the gun on my answer, that was before I studied the wiring diagrams...
There are some differences between the `86 and the later (87-90) model harnesses, the first thing I noticed was the difference in the turn signal circuit. I think you may need to keep looking for an `86 harness, or consider an aftermarket system such as the Ultima.
Is the main harness too far gone to save? How about the switch harnesses and the dash harness?
Old Mar 28, 2019 | 08:02 AM
Racepres's Avatar
Racepres
Is the current Harness beyond rewiring and repinning??
Those jobs are why God made Winter around here....
Old Mar 28, 2019 | 08:21 AM
texashillcountry
Dirt don't hurt
There are some differences between the `86 and the later (87-90) model harnesses,the first thing I noticed was the difference in the turn signal circuit. I think you may need to keep looking for an `86 harness, or consider an aftermarket system such as the Ultima.
Here's the thing owner told me it was an '86 then a couple days later told me it was an '87 so I checked the vin and sure enough it's an '87.
I'm putting on a new main harness, new switch harness, and a new dash panel complete with a new harness for it too.
I'm gonna make a harness for the tail light and rear turn signals.
The light sockets in the dash were very rusted and I couldn't find just the sockets go that's why the new dash pannel.
Every connection on this bike is heavily corroded.
Hell I broke the left front turn signal just trying to get the bulb out!
Not sure how long it sat out in the rain but it must have done it a lot!!!!!!!!
The rear tire is 9 years old, not sure about the front as I think the date code is covered by the table lift clamp but it has weather cracks in the sidewall.
The hell of it is this job started with just a simple tin swap!!!!!
Old Mar 28, 2019 | 08:28 AM
lmz5150's Avatar
lmz5150
If it's an 87, will the 70216-87a be the correct harness? There are a bunch of reproduction harnesses on ebay if so
Old Mar 28, 2019 | 08:32 AM
texashillcountry
Dirt don't hurt
Yep found one and I think the owner has ordered it by now.
Old Mar 28, 2019 | 08:52 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Mike, keep us posted on this rehab, it sounds like an interesting project.
It`s always nice to see an old neglected machine of any type fall into the hands of an owner who wants to bring it back to life.
