FXR Gearing Question
Old Apr 27, 2019 | 06:07 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by 86glider
Food for thought...... You can improve it's performance by cam, carb and pipes to make it more fun then a bigger pulley in front to bring down the revs?
That would be a smart choice cause your gonna need it if you go to a 6 speed or a higher gear.... The nice thing about doing a cam, air cleaner and pipes only is that you're really not going to do much to the reliability of the motor and you'll actually even pickup fuel mileage believe it or not...
Old Apr 27, 2019 | 06:57 PM
splattttttt's Avatar
splattttttt
What size are the stiock pulleys on a 86fx?
Old Apr 27, 2019 | 07:10 PM
Tonebender's Avatar
Tonebender
It has a mild cam, Super E with the Thunderjet. The heads were flowed and dual plugged and the pipes are Pythons. The bike runs great and there is no issue with performance. It just seems to be turning more RPM's than necessary at highway speeds, certainly more than my newer bikes with 6-speeds. Having that taller gear has to be better for the engine. There is a shop nearby that specializes in FXR's believe it or not. I will consult with them.
Old Apr 27, 2019 | 07:16 PM
98hotrodfatboy
nonsense...
Old Apr 27, 2019 | 07:19 PM
TwiZted Biker's Avatar
TwiZted Biker
I see it's an FX chassis but whats with the FL tins and front end?
The up grade to a Six is worth it... I did it in my 98...
86 is a bag of worms to change over, he'll have to upgrade the primary covers , complete starting system, and the clutch hub and guts to go to a 6. 86 still used the old tapered trans main shaft , starter and clutch assembly.
OP, consider a bit more horsepower motor wise, cam & compression and then go up one tooth on the trans sprocket and you can still keep the same belt.
Old Apr 27, 2019 | 07:33 PM
splattttttt
Swap out the pulleys front and rear. Fifth gear will feel like sixth
Old Apr 28, 2019 | 06:50 AM
Tonebender's Avatar
Tonebender
Thanks for all the comments. The '86 is a bag of worms. I have had a lot of fun with mine over the years as you can tell. As a teen all I wanted in life was a Super Glide (Shovel). I started with a '76 Sportster in 1979 because that was what I could afford. By the time I was financially able The Evo's had hit the market. The rest is history. I wish I could be buried with it.
Old Apr 28, 2019 | 02:02 PM
splattttttt
Great post Tone bender
fxrer
EVO
14
Jul 18, 2025 03:53 PM
dodgeman568
Jul 12, 2012 05:40 AM
creekhed1
Apr 17, 2011 10:55 PM
Tackdriver
Sep 14, 2008 01:18 PM
Zzyzx
EVO
Jul 11, 2008 01:35 PM
