Do you know what jets you have now?
I've got spares if you need them.
To be honest I have yet to have to mess with it since I got the bike but I bought a basket case and have been in and out of the country the last couple years. Got everything done on the bike besides just fine tuning.
So pulled the bowl off today and changed the jets out. On the bike was a .74 main and stamp on the intermediate is a 31. I put in a .72 and the 295 intermediate. Took it out on the highway and it runs exactly the same. Steady acceleration at part throttle but full throttle is cutting in and out and jumping. Do I need to go even leaner on the main?
31 &74 are what I'm running in my 111.
Your jets are good make sure the passages are clean.
I doubt it's your problem but look at that little rubber accordion thing the accelerator pump rod runs through.
I had a problem with mine but it caused problems at idle not wot but it's worth checking.
Will have to pull it off and check again. Need to redo my oil lines behind the backing plate. The guy that had the bike before me changed everything and not digging the routing or the way the plate sits against the breather bolts.
Make sure you spray some carb cleaner through the air bleed as well,
You aren't running a fuel filter are you?
So after riding the bike all week after getting everything adjusted it rode pretty good. I only found one problem is. If the throttle is pinned all the way then it starts cutting out and not gaining speed. If I back off just a c*nt hair then it stops cutting out and starts gaining speed again. Is this a main jet being too rich issue or possibly throttle adjustment issue? This happens at 70+ mph.
I'm pretty sure your going the wrong way with the Jets.
By the above statement and the fact that you are not sure what is in the motor I would try a .076 for the main jet. The fact is, at wide open throttle your sputtering but if you back off the throttle decreasing the amount of inlet air a little it smooths out. You see by backing off the throttle a tad you're changing the fuel mixture to less air with the same amount of fuel making the mixture richer. So if you want to run wide open throttle you going to need more fuel. I think you should go up in jets not down..
By the above statement and the fact that you are not sure what is in the motor I would try a .076 for the main jet. The fact is at wot your sputtering but if you back off the throttle (decreasing the amount of inlet air) a little it smooths out. You see by backing off the throttle a tad your changing the fuel mixture to less air with the same amount of fuel (making the mixture richer) so if you want to run wot your gonna need more fuel...
For an 80 in motor????
No way man.
There must be something else going on here but I'm not sure what.
