New setup problems, help please!
Hey gents, going to make this as short and sweet as possible, gotta work in a few hours, but there's a lot going on here. So, this is my fourth season with the bike. Up to the end of last season, mods were as follows: slip on mufflers with packing removed. Big sucker air cleaner with stock cover. Carb cleaned up, 48 pilot, 180 main. Save for the occasional hiccup, bike has started ran and rode without issue. Over the winter I did:Cobra dual head pipes (turns out my stock pipes had a crack, could have been my decell popping...) inner cam bearing, ev13 cam, johnson lifters, new oem breather gear and dyna plug and play ignition. Again, trying to keep this short, but.... bike starts and rides with no issue. Very well behaved, no popping or snorting of any sort. Ignition is dialed in with voes on and second most agressive advance curve, per the instructions. I also put a new cam sensor in, and setting static timing with the dyna is a breeze. The only other change I made was to drop the n65 needle in the carb along with a new slide from cv performance, I happened to have the needle kicking around and wanted to give it a whirl. At any rate, the results are not what I had hoped. Same power, if not less, than last year. Low end power is abysmal. Over 3k it starts to come on and will definitely rev past the 4800 where it used to fall off, but roll on power under even 4k is just not there. And the sound, It just doesn't sound right. To be honest, my dad had an early yamaha royal star boulevard with the de-tuned vmax engine and 4 drag pipes. It was pretty damn cool for what it was, but I digress....my bike now sounds very similar to that 4 drag pipe yamaha. I could chalk up the different sound to the true dual headpipes, and I expected a little loss in low end with them, but from all that I've read, this thing should rip pretty good for what it is and it just doesn't. The final nail in the coffin, some blue smoke from the rear jug muffler. I remember a bit from years past, but with the factory head pipe system, who knows. now I know its the rear jug. So at the moment, rocker covers are off, everything looks perfect. Maybe a burned valve? I can give more pics and details tomorrow, just gotta get some rest at the moment. Thanks for any input, you fellas are the best! Oh yeah, I dropped factory ignition back in, just to eliminate that variable, same identical result.
