Fork oil...
Old Jun 20, 2019 | 01:49 PM
tomfiii's Avatar
tomfiii
Went with heavier weight once; ride not too bad ,but expansion strips were a wrist turner!
Old Jun 20, 2019 | 03:11 PM
Dr.Hess's Avatar
Dr.Hess
I have the HD stuff in my bikes right now. I think next change I'll try Toyota ATF, as that is exactly what the MoCo stuff looked like. Using the vacuum pump, it is easy to change if I don't like it.
Old Jun 20, 2019 | 03:17 PM
Crashone's Avatar
Crashone
You'll be surprised how much junk comes out of those when you change the oil. You could go all out and pull them down and flush them real well.
Old Jun 20, 2019 | 03:19 PM
t150vej's Avatar
t150vej
Yeah I always ran Dexron II in the Triumphs and tried it once or twice in the Tour Glide. It was ok but just seemed like genuine Type E held up longer. Could have been a mental thing. Fork oil is definitely the easiest thing (on an air ride) to experiment with.
Old Jun 20, 2019 | 04:29 PM
splattttttt's Avatar
splattttttt
Air... What a headache that must be! Can never trust a shrader valve or their like.
When it comes to lubes though? And as far as for what it is that it’s designated for, I tend to follow the book. Because the differences can be confusing.
That said, Dexron ll, Toyota ATF and the MoCo’s secrete formula type 3, to me makes no difference, since I don’t know the what each one of them are. Talk about snake oil LOL
For instance. Bel Ray recommends 10W. My current cage uses synthetic 20w.
Is it safe to assume synthetic 20W is twice as heavy/lighter then the Bel Ray 10W? Which by the way, is sold as a hydraulic fluid.
Old Jun 20, 2019 | 04:42 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by splattttttt
When I road raced back in the eighties. We all experimented a lot with oil weight. Spacers and springs. Even rake angles.
We took many chances. But leaned a lot.
That was a long tome ago and other than valving snd cartridge snd up side down yada yada. Suspension is a very simple application still.
as you say... it’s all feel and personal preference.
If I had the time to try the 20 weight and replace it if I didn’t like it, I would. But since I was very happy with the original feel of the fork when new. I’ll just do the 10 weight.
Granted forks are probably a little tired. Maybe a 1/2” spacer would help LOL
Yeah .. I did that 2... 1/2” does make a difference..
Old Jun 20, 2019 | 05:00 PM
splattttttt
Old Jun 20, 2019 | 09:11 PM
Mountainkowboy's Avatar
Mountainkowboy
It all depends on how you like the feel of your ride... I use 20w.. Less dipping going into the corners and a nice firm feel..
I also had gold emulators, and will buy them again, 20wt and ATF were to harsh with them.
Old Jun 20, 2019 | 09:32 PM
1997bagger's Avatar
1997bagger
Had 20w Belray Synthetic and ride was firm, recently removed the stock springs changing to single rate springs with Synthetic ATF for Isuzu trucks that is setting everywhere in the shop and rides better. The Belray removed was in for around 8 years looking like it was new when draining it.
Old Jun 21, 2019 | 02:33 AM
splattttttt
Good info 97bagger
Mountain, how hard is it to install those immulaters? Hear all kinds of positive inputs about them. Thanks bro
