Help with a stalling problem
Old Jun 26, 2019 | 09:56 PM
misfitJason's Avatar
misfitJason
Default Help with a stalling problem
Help me figure out my problem here because I can't figure it out.
Bike is a custom built softail that I built. I built it with an oem 80 inch evo and up until about a month or two ago it had no problems. I recently bought a brand new s&s v111 and swapped it into the bike. Carb is a super e (same one that I ran on the 80 inch) with a 32 intermediate and 78 main. No adjustable air bleed. I have about three hundred miles on the motor as I type.
The ignition is a dyna S set appropriately for this motor.
I have confirmed I do not have an intake leak and am using all of the appropriate hardware for this carb and motor.
The motor runs excellently except it stalls every so often on decel and sometimes will stall at idle. At any type of acceleration it has no issues and runs strong. When it stalls it coughs. The idle air mixture (whether rich or lean) doesn't make a difference on the stalling. After it stalls I can start her right back up.
None of these problems existed before he motor swap with all the same parts. I have since rebuilt the carb and changed the coil with no difference. My next thoughts are my mechanical advance (although it turns free and easily) or possibly there is crap in my tanks causing a issue with gas feed. Again I am running the same parts that I was with no problems before.
The spark plugs look good as far as the mixture goes. I even replaced the plug wires. No difference.
Any suggestions that you guys have I would appreciate. Thanks in advance.
Old Jun 26, 2019 | 10:10 PM
daven9113's Avatar
daven9113
Check for exhaust leak? Not a fuel issue, so leaning towards timing maybe. Just something to look at.
Old Jun 27, 2019 | 04:36 AM
misfitJason
Thanks. Definitely not an exhaust leak
Old Jun 27, 2019 | 05:35 AM
kero's Avatar
kero
Maybe some debris on idle circuit?
Old Jun 27, 2019 | 06:45 AM
98hotrodfatboy's Avatar
98hotrodfatboy
You don't have a loose throttle plate or possibly a worn shaft, do you?
You might want to think about going to a G if you got a run jets like that... That's a lot of fuel for that small carburetor and you got to remember that E isn't even 40 mm...
One more thing, don't they sell that motor in 2 different configurations? Compression and cam... Which one you running?
Old Jun 27, 2019 | 07:00 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The last time I had problems such as you describe the problem turned out to be that black rubber accordion looking boot that covers the accelerator pump rod.
It had dry rotted and was letting in air to the accelerator pump system.
Old Jun 27, 2019 | 08:58 AM
misfitJason
They recommend the e for this motor. I bought the long block that came with just the motor. In 9.8:1 compression with the v585 cam
I'll take a look at the carb shaft. My petcock is a Golan. I haven't checked the screen yet. I feel if it was starving for fuel for lack of flow it would be evident at more throttle and not decel or idle.
Old Jun 27, 2019 | 09:47 AM
texashillcountry
Dirt don't hurt
The reason S&S recommends the E for the 111 is you get snappier response at low and mid range but suffer a bit at WOT.
Since most people don't spend much time at WOT they went from a G to the E.
Old Jun 28, 2019 | 12:28 PM
misfitJason
I tore into a couple of things.
The fuel line was new when I changed the motor. It still does it no matter where I route the line. The mechanical advance looks good and moves free.
The cam seal is leaking a little. Will eventually have to change that out. All of the wires coming from the ignition module are intact and good.
Texas.... that little black boot on the plunger looks like this when I took the picture. I can't remember from memory if it's supposed to be all the way up or not. That could be a possibility.
The butterfly on the carb is nice and tight and not loose.
I don't have time to check the petcock screen or tanks. There could be some crap in there. I would also like to run a compression test on the motor when I take the tanks off to check them for debris. But I'll have to unplug the acrs. Can anybody think of anything else or see anything that jumps out at you?
Old Jun 28, 2019 | 01:07 PM
texashillcountry
Dirt don't hurt
When I was having my stalling problem that little boot had dry rotted in several places.
I couldn't see it until I removed the boot.
After I replaced it my stalling problems went away.
