New noise today
Old Aug 11, 2019 | 04:45 PM
Newharleylover's Avatar
Newharleylover
Default New noise today
I went for a ride today and a new noise came up. It's a tapping or clanging type of noise coming from somewhere near the front cylinder on the right side at idle. Had a couple backfires while going around 75 mph on the way home too. It's got 77,000+ miles on it. Bought the bike a couple of years ago and the previous owner didn't give me a whole lot of info on it's history. But it ran great and is in pretty good shape for an old bike so I bought it. So the question is because of the tons of reading I've done here I've read about collapsed lifters. In any of your opinions is this an indication of a collapsed lifter and if so what do I have to do to find out if it is?
Old Aug 11, 2019 | 09:14 PM
terrapin88's Avatar
terrapin88
I'm no expert, but I did stay in a Holiday Inn Express. A bad lifter makes an attention getting tapping sound. Not sure about the clanging type of noise you mentioned. The sick lifters I've heard made a loud tapping. If you gently raise the RPMs in neutral, the bad lifter might tap louder. That was my experience.
Old Aug 11, 2019 | 09:39 PM
Newharleylover
I would say tapping would be a more accurate description. My hearing is crap so my head was as close to the engine as I could get to verify where it was coming from. I wear ear plugs occasionally and without the wind noise I heard it at 75 mph. At idle it's very noticeable. Revving it up makes it louder as you mentioned. All I can tell is it's coming from the lower part of the front cylinder but the lifter blocks are there which is why I'm guessing it's a collapsed lifter.
Old Aug 11, 2019 | 09:46 PM
terrapin88's Avatar
terrapin88
That sure is what it sounds like from your description.
Old Aug 11, 2019 | 10:00 PM
Beemervet's Avatar
Beemervet
Pull the push rod tube clips and see if a push rod is loose.
Old Aug 11, 2019 | 10:29 PM
RCermak's Avatar
RCermak
Default New noise
If the cam bearing is original could be that also 70,000 miles both are weak points
Old Aug 11, 2019 | 11:23 PM
t150vej's Avatar
t150vej
May be wishful thinking but...
I dropped off a ramp for fuel in Nebraska once and just knew I'd either dropped a valve seat or lost a lifter halfway up the ramp. Hell of a racket that changed with RPMs too. It was a broken tab on the upper front heat shield. Ha! Wrapped a hose clamp around the outside and went on with my trip. So check that heat shield before you go adding up parts Hope that's all it is on yours.
Old Aug 12, 2019 | 06:21 AM
Newharleylover
I'll check for loose heat shields before I get further into it. I replaced one last year because the tabs on the back side broke off. It backfired a couple of times on the way home on a flat stretch which caught my attention. I have new intake and exhaust seals and gaskets which I've tested for leaks after I put them on and all is good. The S&S super e that's on it is running a little rich so I've ruled the lean condition out of the equation. It was a preventative maintenance thing I did this spring. Far as the cam bearing and everything else I'll have to further diagnose things as I go. Process of elimination I guess
Old Aug 12, 2019 | 08:10 AM
86glider's Avatar
86glider
Those early lifters were problematic and should be replaced.
Old Aug 12, 2019 | 11:24 AM
Son of PMS's Avatar
Son of PMS
Put the tip of a long screwdriver on the lifter block. Put the handle against your ear. You’ll hear it.
