‘97 FLHR idle cable spring install
Old Sep 9, 2019 | 10:06 AM
GOGOBECK's Avatar
GOGOBECK
Default ‘97 FLHR idle cable spring install
I replaced the idle cable some months back... while removing the old cable the spring went “ping”, never to be found again. How it wasn’t wound around the inner cable I don’t know!
I picked up a replacement spring from a dealer.
This springs diameter is too large to fit in the cable guide and too small to go over the cable ferrule!!!
I can understand the ferrule part, but not cable guide.
What am I missing?
Old Sep 9, 2019 | 10:13 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Every idle cable I've ever bought came with the spring on it.
I've never tried to replace it or buy it separate.
Hell I didn't know you could!!!!!!
Old Sep 9, 2019 | 10:18 AM
GOGOBECK's Avatar
GOGOBECK
Yeah, I’ve never had a throttle or idle cable with a ferrule on the end either!
I guess I’ll just reassemble without a spring, the ferrule is almost a pressure fit in the cable guide.
Old Sep 9, 2019 | 10:25 AM
texashillcountry
Dirt don't hurt
Either that or just buy a new idle cable or depending on age replace both cables.
I like Barnett.
Old Sep 9, 2019 | 10:31 AM
GOGOBECK's Avatar
GOGOBECK
Not a bad idea to just replace both cables. I installed a Barnett clutch cable last fall, one of those coated jimmies... made a believer out of me, don’t think I’ll buy anything other than Barnett cables going forward.
Old Sep 9, 2019 | 01:43 PM
texashillcountry
Dirt don't hurt
I know I won't unless it's an emergency like I broke a cable on a trip then I'd buy any damn thing I could find but I would replace it with a Barnett as soon as I got home.
Old Sep 9, 2019 | 04:09 PM
V-Twins & Bowties's Avatar
V-Twins & Bowties
To get the spring on, you need to start it on the cable at one end of spring. Then twist/ screw the spring till its on, all the way, over the cable.
Old Sep 9, 2019 | 05:09 PM
texashillcountry
Dirt don't hurt
Why would he want to put that spring on the cable if it won't fit into the cable guide???
Old Sep 10, 2019 | 05:18 AM
V-Twins & Bowties
OOPS. Excellent point, brain fart.
Old Sep 11, 2019 | 09:03 AM
carlgrover's Avatar
carlgrover
Just for fun I looked this thing up. I'm assuming you have a carb and not FI. Here's a link to the spring. It's part of F/N 11, idle cable assy.
http://partsfinder.onlinemicrofiche....=35&c=0&d=1997 FLHR ROAD KING® (CARBURATED) (FD) THROTTLE CONTROL ASSEMBLY W/ GRIPS
I don't see a separate P/N. I'll take a guess and say you've been sold the wrong spring.
carl
