View Poll Results: Can you provide pictures or videos of reinstalling front wheel on Springer
SM Diagram Explained
0%
SM Instructions Clarified
0%
Pictures Provided
0%
Videos Provided
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Softail Service Manual Diagram
Old Sep 10, 2019 | 03:33 PM
MacRanger's Avatar
MacRanger
Stage I
Unhappy Softail Service Manual Diagram
Hey All--Doing some Caliper, Rotor & Pad R&R on the front end of my '99 FLSTS (Heritage Springer), and like a Dumb@$$ I failed to take pix of the axle as I removed it from the hub. Anyway, after nearly 3-days of heavy duty scrubbing, grinding and polishing I've all the pieces and parts back where they need to be (on the wheel and caliper), but I cannot figure out from the SM diagram (Fig 2-6 (p. 2-8) & Fig 2-7 (p. 2-13)) how to get all the spacers & washers back on in the correct order and location. The diagram drawings are not real clear! Does anyone have some good pix--or maybe even a video--showing the correct order and placement of the Spacers, Sleeves, Washers, & Seals. I'm pretty good with the Rightside of the Forks (Springer & Rigid). It's the Leftside that is kicking my butt.
Old Sep 10, 2019 | 05:44 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Install bearing into one side, install seal.
Flip wheel over, install sleeve, shims if needed, spacer with shoulder facing out, install bearing, install seal.
Remember, shims go between the sleeve and the spacer with the shoulder on it, the shoulder faces toward the outside.
Does not matter what side the shims and the spacer go on.
Did you replace the bearings, do you need to set end play, if so, no problem it`s easy.
Old Sep 12, 2019 | 07:41 AM
grbrown's Avatar
grbrown
Wink
One of the parts websites may help, such as Ronnies? That will show the order that parts assemble.
Old Sep 12, 2019 | 08:10 AM
evotrike's Avatar
evotrike
stover954rr
Apr 4, 2013 04:23 AM
tootall61
Aug 29, 2010 11:43 PM
chadcowan
Aug 16, 2010 06:42 PM
gorilla
Apr 23, 2007 01:37 PM
bartab
Mar 29, 2006 01:52 PM
