New here
Old Sep 15, 2019 | 03:01 PM
carlgrover's Avatar
carlgrover
Welcome to Evo land.
Your camera broke?
carl
Old Sep 15, 2019 | 05:35 PM
Mountainkowboy's Avatar
Mountainkowboy
Welcome to the forum....presently in Oregon. Most likely a poor connection, as others have said, clean all connections first.
Old Sep 15, 2019 | 08:46 PM
0maha's Avatar
0maha
FWIW, my 1990 was getting a little ishy on starting last year. First push of the starter button would, maybe half of the time, produce a nice click and nothing else.
Last winter I did a bunch of stuff to her, including relocating the battery under the seat. That necessitated shortening the battery cables. I also pulled the solenoid out and gave it a good clean. And redid the cable ends and gave everything elsr a nice clean too.
After all that, she fires right up. First time, every time.
Old Sep 16, 2019 | 08:18 AM
nibroc's Avatar
nibroc
yep---ya hafta have clean connections esp the grounds
attaboy15's Avatar
attaboy15
Welcome from Norcal
Old Sep 16, 2019 | 05:56 PM
yellowstone kelly's Avatar
yellowstone kelly
Originally Posted by Fenton Fadeley
First issue is that it will not start. Good battery, good starter relay, seems like it maybe grounding out. Hit the starter button and it clicks.
Welcome to the forum from SW Iowa.
All good info and suggestions so far...
If it were mine, the first thing I would determine is "exactly what is clicking" when you push the starter button.
As you probably know, the starter button sends power to the starter relay which sends power to the starter solenoid, which sends power to the starter motor.
Since you hear a click when you push the button, the starter button seems to be working OK.
Assuming the starter relay is really good like you say ... (how do you know unless you've used a voltmeter at the solenoid to see if +12 volts is getting to the "trigger" post when you hear the click?)....then the next thing to check is the solenoid.
Without a voltmeter, you're just guessing when it comes to electrical problems. And guessing can get expensive real quick.
Good luck in getting this fixed! You can do it if you use the right tools and this forum.
Old Sep 16, 2019 | 06:18 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
No, not especially the grounds, all connections...
People are fixated on grounds....
Ground connection, positive connection...equally important.
It`s a circuit, a poor connection anywhere is a poor connection.
Old Sep 23, 2019 | 11:25 AM
hdbob2006's Avatar
hdbob2006
Agreed Dan-a bad ground can cause problems,but a bad positive connection can cause heat,can cause melted cables,melted positive battery post,and sometimes even a fire.
Old Sep 23, 2019 | 12:00 PM
eglide_vt's Avatar
eglide_vt
Welcome from Vermont.
As with others...Verify battery is strong and clean all connections before anything else. Good luck.
Old Sep 23, 2019 | 12:02 PM
Fenton Fadeley's Avatar
Fenton Fadeley
6th Gear
Grounding out, what does that mean?
Fully charge the battery and have it load tested, until you do that don`t tell us the battery is good, even if brand new...
Clean up all the electrical connections for the battery and at the relay and starter solenoid, don`t just check to see if they are tight, take them apart and clean them.
If the problem still persists after doing the above, get out your voltmeter, and keep your wallet in your pocket.
Don`t go out and start buying parts.
Thank you, I am digging into the wiring harness and am finding issues to sort out. Going to take care of the obvious. The input you provided is most helpful.
