With regards to clutch adjustment - as stated in the OP, this has already been done to factory service manual spec. (Not sure why that when I say I adjusted the clutch to spec it's assumed that I only did the cable...)
The issue existed before I did the primary fliud service, and continues now as well. I did try the "blip the throttle" method, and that does work. So at least I can get the bike into neutral at a stop now. But I would like to address what's actually causing the problem. So I'll continue to diagnose.
The primary chain being too tight sounds like a pretty likely culprit - so I'll check that next. Thanks!
Check the shift pawl adjustment it could be another likely candidate... Has the bike sat for any period of long time cause sometimes from sitting the steels will rust a little creating less separation for the friction plates.. I only say that because you said it's hard shifting out of first..
I had an issue similar years ago.....I just remembered
The clutch plates were digging into the clutch hub.....therefore the plates were sticking. I couldnt find neutral and the bike crept forward with clutch pulled in.
If you are running 20w50 dino in the primary, try some 10w40 synthetic motorcycle oil instead... I've been surprised that a tough to find neutral cares about oil weight, but it definitely makes a difference on my bike. The other that seems to help, is to fully collapse the clutch cable, and use a wrench on the lock nut to loosen it all the way, and a wrench on the barrel adjuster to collapse it all the way. Just as tight as you go with fingers is still a 1/4 turn or more with a wrench. That's a decent amount of adjustment at the clutch hub pushrod/lock nut, and gives you a bit more throw at the hub.
Finger tight collapsed on the clutch cable I always had a bit of creep in first gear at lights and a bang going into 1st. Totally collapsed, wrench tight... neutral is easy and 1st gear from neutral a lot less noisy.
Happens to me once in a while, I leave it in first, hit the gas and release clutch just a little, pull clutch in again and it will go right into neutral.
Thanks all - I adjusted the primary chain and all good now. It was a bit tight, and that was it!
Glad to hear you got it taken care of. You might also want to consider what ZackE mentioned.
Occasionally, very seldom in my case. I will loosen the adjusting hex nut all the way out and then tighten it down snug. I do this a fee times sought of like Im chasing it just to loosen up debris or gunk that might cause a clearance issue. Good precaution and does help
Then to the actual adjustment... I usually turn the adjuster hex screw in with finger is till it taps. And lock it there.
My 1996 Road King has been experiencing shifting to neutral while running problems for years. Somebody in the thread suggested to "burp" the throttle by giving it a little rev and shifting toward neutral at the same time. I have been doing it for about a month now and it has never failed to work. For whatever reason (magic, gremlins, etc.) that it requires this - the "little burp" works for my bike. Thanks for the information.
