Transmission won't go into neutral...
Old Oct 3, 2019 | 08:36 PM
sgr60's Avatar
sgr60
Default Transmission won't go into neutral...
Hi all -
Hoping someone has some advice on this. I've got a '92 FXR and it won't shift into neutral when the bike is running and at a stop. Have to put a pretty large amount of pressure on the shifter from 1st, and it then just goes right to 2nd. Down from 2nd is easy, but goes right by neutral.
A few additional notes:
1. Can find neutral fine when the bike is off
2. Can also find neutral fine when the bike is running and moving
3. Just did a full service on the bike looking to address this - new trans/primary fluid, clutch adjusted - everything is to spec.
Any thoughts???
Old Oct 3, 2019 | 09:55 PM
OLD 96's Avatar
OLD 96
You might want to look at throw out bearing.
Old Oct 3, 2019 | 10:16 PM
ChopperBill's Avatar
ChopperBill
Too much free play in your clutch.
Old Oct 3, 2019 | 10:26 PM
yellowstone kelly's Avatar
yellowstone kelly
I can tell you that both my '96 Heritage Classic and my '82 Ironhead Sportster have always had this same issue since I've owned them. And I bought the Sportster brand new in '82.
I eventually figured out with both of them that I have to blip the throttle while shifting from 1st gear up into neutral, and it slips right in.
Maybe there's something I could adjust or fix to help with this, but my method has worked for me for years and it works every time. And it isn't getting any worse, so I've always thought it's just a "Harley thing".
Old Oct 4, 2019 | 05:15 AM
pjb's Avatar
pjb
I don't want to get into a battle about the best method and procedure, but what you need is a proper clutch adjustment.
Not just a cable adjustment, but a complete clutch adjustment.
It's easy, just follow the correct procedure for your bike.
If that doesn't fix it, then you have clutch parts that need replacement.
Again, very simple.
Old Oct 4, 2019 | 05:34 AM
EVOrider's Avatar
EVOrider
Again, very simple.
I agree....start with proper clutch adjustment at the unit. Then adjust the cable last. You shouldn’t have to shut the bike off or even blip the throttle to find neutral.
Old Oct 4, 2019 | 05:49 AM
98hotrodfatboy's Avatar
98hotrodfatboy
How many miles and is it the original setup. Did this all start after the fluid change in the primary or was it an existing issue? What fluid are you using? Is the primary chain too tight? I would take a Dial indicator and measure the amount of movement at the clutch spring plate. That would give you an indication. You should have at minimum .068" of throw.. if not check adjustments and recheck..
Old Oct 4, 2019 | 06:00 AM
pjb's Avatar
pjb
That's doing extra effort to verify what is already known.
Just do a proper adjustment and be done.
Same goes for the guy that has to blip his throttle.
Old Oct 4, 2019 | 06:37 AM
flhchaz's Avatar
flhchaz
I'll bet that the rivets in the spring plate are coming out and jamming everything up. Been there with these symptoms.....
Old Oct 4, 2019 | 06:55 AM
Tom84FXST's Avatar
Tom84FXST
IMO the primary chain too tight is the number one cause of hard to find neutral...
