Evo build start up..
Old Oct 13, 2019 | 07:04 PM
chop13's Avatar
chop13
Default Evo build start up..
Hey guys, been a real help here lately so might as well ask my last question.
went to fire up the pig today, all excited and happy.. then nothing but whooshing coming from the bike.
Has to be valves opening, so I thought it was timing, but not wanting to hurt anything as I didn’t hear any metal contact on startup. I went back into the adjustable pushrods.
I set them as usual, but remembered that this pig has compression releases. I recall hearing of a different method to install rods with releases, but don’t remember exactly how?
any truth to this? I readjusted the front using the flyweel peep hole and made sure it was Tdc compression and made sure the rear is tdc. I possibly was off tdc a bit first go around, but that never was an issue before.
also, I’m running a wood 8 hi lift cam and was also wondering if the ss rods still require 4 full turns?
so really it comes down to compression releases, pushrod turns or timing.
any help is appreciated gentlemen!
Old Oct 13, 2019 | 08:42 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I take it the wooosh your hearing is lack of compression... Timing and compression releases ain't gonna do it. Most likely the valves didn't bleed down or you set them to deep... ALWAYS TURN THE MOTOR OVER BY HAND AFTER ADJUSTING THE PRELOAD ON THE VALVES... ALWAYS.... Set to .140"...
Old Oct 13, 2019 | 09:22 PM
chop13's Avatar
chop13
Thats the thing, I gave lifters ample time to bleed down and spin by hand and rotated the rear wheel by hand before ever powering up and cranking it. Gave it a crank, no go and back on the jack. I pulled the heads earlier and valves looked good.
Old Oct 14, 2019 | 07:02 AM
misfitJason's Avatar
misfitJason
Compression releases have nothing to do with your pushrod adjustment. Two different animals. That only comes into play on a Twincam when using S&s cams with built in compression releases
Old Oct 14, 2019 | 07:18 AM
Rsbenden's Avatar
Rsbenden
https://www.sscycle.com/tech-info/in...ruction-sheets
lespaul60
Engine Mechanical Topics
15
Aug 25, 2018 08:46 PM
F86
Aug 28, 2017 04:30 PM
stick93
Sep 5, 2014 03:04 PM
user 59756875865
Jun 19, 2014 10:14 PM
htrod9592
EVO
Jan 13, 2010 07:16 PM
