Primary drain plug
Old Nov 22, 2019 | 11:19 AM
JensWest's Avatar
JensWest
Default Primary drain plug
I have a -92 FXSTC.
Which size of allen key should be used for removing the primary drain plug?
I've tried 7/32, 3/16, 5/32 and 5 and 4 mm and none of them work...
Old Nov 22, 2019 | 11:52 AM
larsfum's Avatar
larsfum
I believe that is a Torx head on that plug. T-27 I believe.
Old Nov 22, 2019 | 01:49 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by JensWest
I have a -92 FXSTC.
It's either a T35 or T40 I don't remember which off the top of my head.
I'd lean more to the T35.
Old Nov 22, 2019 | 02:21 PM
LQQK_OUT's Avatar
LQQK_OUT
According to the book:
101 Harley-Davidson Performance Projects For Evolution Big Twins And Sportsters
by Kenna Love and Kip Woodring
Copyright: 1998
MBI Publishing Company
This is the infamous #739A drain plug. It's used for both the tranny drain and the primary drain on most Big Twins, and it's been through a couple of changes over the years. The early plug has an Allen head, and frankly, the magnetic tip had a tendency to come loose, sometimes falling into the motor. Second, the plug is a fine thread going into aluminum, therefore, a prime candidate for getting stuck in its hole or stripping out. It's a fine plan to have at least one new one of these on hand during fluid changes. The latest version is a Torx head, with a secure magnet and Teflon on the threads so finger tight and half a twist will keep it secure and hassle free.
3/16" Allen wrench for early model drain plugs
T-40 Torx wrench, for late model drain plugs
FYI: According to the notes in my shop manual, it's a T-40.
But, then there is this information:
Originally Posted by texashillcountry
You might want to take a closer look at it.
The plug part number is 739A which is used on a shitload of primarys.
(All the EVO ones I looked at) and it is actually a T-30 Torx head.
Don't get me wrong you can easily take it out with an allen but it is actually a torx.
Last edited by LQQK_OUT; Nov 22, 2019 at 02:27 PM. Reason: updated post with my factory shop manual notes
Old Nov 22, 2019 | 03:01 PM
JensWest's Avatar
JensWest
Never thought it would be a Torx after looking at it.
But yes, it was a stripped T30 one there.
Any suggestions on how to remove one of those?
Old Nov 22, 2019 | 03:21 PM
bentparts's Avatar
bentparts
Default stripped Torx removal
You could try hammering in a larger allen head either metric or standard using a ratchet.
Old Nov 22, 2019 | 03:29 PM
Yankee Dog's Avatar
Yankee Dog
Get a t-45 torx bit and grind it down to a point. In other words, grind a slight taper in the tip of the bit so it is smaller than the rest of it, and tap it in carefully with a small hammer. Attempt to get a good bite and try to back it off. YD
JensWest's Avatar
JensWest
Aaand same thing with the one in the transmission...
But that one seem to have been a T40.
Old Nov 22, 2019 | 03:32 PM
dgwv's Avatar
dgwv
I had a stripped Torx that I couldn't get out. I was able to hammer in a larger Torx and got it out. I've also used a flat chisel and hammer a slot for a flat screwdriver.
Old Nov 22, 2019 | 04:23 PM
texashillcountry
Dirt don't hurt
Your primary plug and transmission plug are interchangeable.
