cable kit 95 tour glide
Old Dec 4, 2019 | 04:01 PM
Cnyflhx's Avatar
Cnyflhx
Default cable kit 95 tour glide
put some 16inch apes on my 95 tour glide cant seem to find a cable kit for my bike. dennis kirk was pretty lousy when i called them and j and p tried to sell me a kit for a single rotor bike so im kinda at a loss any one know what lengths i should get or what kit i should use???
Old Dec 4, 2019 | 04:06 PM
Mountainkowboy's Avatar
Mountainkowboy
I have better luck finding someone local to make them...visit a hotrod shop and ask who they use. I think my last set were made by Russel.
Old Dec 4, 2019 | 04:18 PM
0maha's Avatar
0maha
For all three (brake lines, throttle, clutch), my $0.02 is to take some flexible tubing and mock up exactly where you want them to run, then go from there.
On the brake lines, the OEM lines can be re-worked by a hydraulic shop, if you get the measurements from above. The alternative is to go with something like Russell or Goodridge and piece a system together from components:
Clutch and throttle can be ordered directly from Barnett. Just give them the measurements you get from the tubing, and they'll take it from there.
Old Dec 4, 2019 | 07:06 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You can also make the brake lines you need buy measuring what you need and order everything from Drag Specialties;
I use either Russel or Goodridge brake lines and connectors.
You will need a couple of line wrenches to tighten up the connections.
Old Dec 5, 2019 | 06:16 AM
flhchaz's Avatar
flhchaz
Try Burley. They have lots of kits.
Old Dec 7, 2019 | 07:52 AM
1997bagger's Avatar
1997bagger
https://hillcountrycustomcycles.com/...oad-glide.html
List kits for your year of bike and heard they use Barnett cables, also have brake line kits. May have to call them to just get the cable and brake kits since you have handlebars but the cable kits may be listed somewhere on the website.
LA Choppers would also be able to fill your needs.
If you want to buy the cables individually +12 will give you some wiggle room, +10 will work but the 2" free's up some routing issues.
Old Dec 8, 2019 | 11:36 AM
50pannmore's Avatar
50pannmore
How about you post a picture of your 95 tour Glide or first generation Road Glide I bet it's a beautiful bike
Micheal Chaco
Mar 19, 2017 07:18 AM
03Custom883
Dyna Parts
Oct 7, 2013 09:24 PM
fourH-Ds
Aug 21, 2012 08:49 AM
3rdgear
Jul 12, 2010 04:48 PM
