Electrical Headscratcher
Old Dec 16, 2019 | 03:53 PM
almostakeeper's Avatar
almostakeeper
Default Electrical Headscratcher
Last week I did all the crimping/heat shrink associated with the front connectors
Yesterday I put the battery in, temporarily connected the rear signals and tail light wiring and hit the switch
All the lights come on including the oil light (everything has new bulbs except the two inside the speedo)
I'm getting an audible click about every 3 to 5 seconds from a relay attached at the bottom of the dash and every light, including headlight, oil light and my test light, no matter where I put it does a blink. The only switch that is working is my high/low beam and nothing happens when I hit the start button. When you hold in the horn button, on occasion whenever the lights blink the horn does a slight death rattle.
On wiring, the only things I cut loose were the ones going to the switch paks, headlight and signals. I not only took many pictures of every wire placement I also mapped it out on paper and wrote every A to B cut down as I cut. Very **** in this so I'm 99% sure its not the splicing.
Old Dec 16, 2019 | 04:02 PM
0maha's Avatar
0maha
Wish I had an idea for you. Those sorts of gremlins drive me nuts.
All I can do is wish you luck!
Old Dec 16, 2019 | 04:08 PM
Dr.Hess's Avatar
Dr.Hess
That's not a relay. It's a circuit breaker. You have a short.
Old Dec 16, 2019 | 04:18 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What model year are the handle bar control switches ?
Old Dec 16, 2019 | 04:19 PM
TSheff's Avatar
TSheff
Any splicing inside the bars???????
Time to get out the DVM and start testing each run.
Old Dec 16, 2019 | 04:23 PM
Yankee Dog's Avatar
Yankee Dog
Yes, it's an automatic reset circuit breaker. So it is tell you that something tied into it is shorting out. As mentioned, time to start tracing things back and going over your work. Good luck, take your time, go slow, you will find it. YD
Old Dec 16, 2019 | 04:25 PM
Tee&Vee's Avatar
Tee&Vee
Yup. Easy but tedious. One wire at a time. Just a guess but when you made the pull inside the bars there is a wire rubbing. As TSHEFF said, get the meter out.
Old Dec 16, 2019 | 04:26 PM
86glider's Avatar
86glider
A way I do a wiring job is to blow up and print out the diagram (hopefully you have the fsm) then use a highlighter to eliminate as you go to be sure you don't miss anything.If after that you still have a short, start unplugging some circuits to pinpoint the problem.Good luck.
Old Dec 16, 2019 | 04:30 PM
Goose_NC's Avatar
Goose_NC
Remove the clicky thingy and replace with 8 guage wire. Follow the smoke.
Old Dec 16, 2019 | 04:46 PM
almostakeeper
Not sure. Seems like everything has been replaced on this bike.
The wires in the bars never got pulled. everything from the switchpaks/bars are unchanged.
I only pulled the left switchpak off earlier today to inspect the wires/look for a pinched wire. I'll pull the right side after work tomorrow and start tracing down the gremlin. Has to be a pinched wire somewhere
