VOES Failure
Old Jan 8, 2020 | 10:00 AM
Racepres's Avatar
Racepres
Originally Posted by Dehammer
Who makes the best VOES switch? Or are they all the same, outside of the pressure setting.
I got a POS switch that didn't stay in place, the retaining ring didn't stay.
Standard Motor products is prolly as good as any...and better than anything from China!!!!
Prolly get it right at yer local NAPA
Amazon Amazon
Old Jan 8, 2020 | 12:23 PM
98hotrodfatboy's Avatar
98hotrodfatboy
standard motor products makes a lot of parts for our bikes that are getting hard to get and are very reasonably priced.. I currently use their pickup plates down in the nose cone of both my shovel and my Evo. Been using them for years never a failure. Coils are responsible as well.. like $80..
https://www.pageturnpro.com/Four-Sea.../0/mindex.html
There's like 32 pages of parts in the link..
Old Jan 8, 2020 | 12:24 PM
Racepres's Avatar
Racepres
standard motor products makes a lot of parts for our bikes that are getting hard to get and are very reasonably priced.. I currently use their pickup plates down in the nose cone of both my shovelandn my Evo. Been using them for years never a failure. Coils are responsible as well.. like $80..
Good job...and thanks for the link... I always do **** the hard way!!!!!
Old Jan 16, 2020 | 08:59 PM
journeymanjohn's Avatar
journeymanjohn
My experience with any type of electric switch (limit switch, relay, starter, contactor, light wall switch... anything with contacts) is that they either work or they don't,.... but then again it might not work this time and work again next time. Intermittent. Contacts corrode. They stick. A bump or temp change might cause it to free up and change to the position it is supposed to be in, but isn't. Will a VOES do this? I can't swear to it, but I would bet on it.
Of course, there is still the vacuum part of it also. I assume that that would be a constant either sealed and working or torn and broke thing, but who knows.... not me.
Old Mar 19, 2020 | 11:46 AM
jgarner's Avatar
jgarner
Stage III
http://www.wildwestcycle.com/f_voes.html
Old Mar 20, 2020 | 06:19 PM
Uncle G.'s Avatar
Uncle G.
The VOES is most likely to fail in the "retard" position, and the most noticeable symptom is a sudden drop in idle speed. That said, I did have a switch fail in the closed or "advance" position. That caused the engine to detonate on acceleration. So, I guess either failure is possible because I've experienced both.
Old Mar 20, 2020 | 07:30 PM
98hotrodfatboy
True Dat... failing open would also decrease the gas mileage...
Old Mar 25, 2020 | 12:16 PM
Uncle G.'s Avatar
Uncle G.
True, but that’s a bit harder to spot right away. The drop in idle speed is immediate and hard to miss. Idle speed will drop from 1000 RPM to about 600 RPM.
HDF Tech
Engine Mechanical Topics
57
Feb 7, 2023 11:32 AM
Jephilosoraptor
EVO
Aug 4, 2015 04:10 PM
gdbuick
Jul 5, 2011 02:33 PM
police
14
Jul 12, 2010 06:10 AM
Corndog
Aug 6, 2008 07:12 PM
