Screamin Eagle heads?
Old Jan 16, 2020 | 09:19 AM
Racepres's Avatar
Racepres
Just so you guys know the programmable SE ignition module was made by Dynatek. It's the same as their 2ki.. infact identical curves..
Maybe you had something when with your SE module..
Never paid no attention to that Either.... next time I'm in the shop...I will tho...I'm getting more and more Allergic to this Cold!!!!!
Originally Posted by texashillcountry
Let me be clear I don't recommend riding away cold it's just very nice that the bike doesn't stumble and die if I add throttle when it's cold.
As for your RWD I highly doubt you will find any difference.
The only difference I've found is with cold starts.
Understood... Our RWD is kinda a fickle Bitch... But... at one time we did gain a Couple tenths with a complicated list of components... Including Beru Plugs, Nology Wires, some crazy MSD stuff with yet a Different Pick-up...which I honestly don't remember the Pick-up!!!!
this on a Dual Plugged, highly modified little [75 inches] Sportster....Only worth it if you really need them Tenths...We Did!!!!
Old Jan 16, 2020 | 10:51 PM
1997bagger's Avatar
1997bagger
SE heads have massive spring pressure and kinda of low lift ability compared to modern beehives, the spring pressure can prematurely wear lifters and valve seals are known to be junk. The raised port design can create a early torque dip in a basic engine.
Raises compression with a simple bolt on, port design in the right hands can create one good running machine in the mid and upper rpm's, larger valves already present plus bathtub design is considered efficient.
The head porter I use (Sachs) wanted my stock heads saying they work better in lower areas of rpm and sell the SE's which I did.
Old Jan 20, 2020 | 06:15 AM
user 47363638's Avatar
user 47363638
I went from a Screamin Eagle ignition to a Dyna 2000, after engine work done the cold starts were a pain in the ***, after installing the Dyna 2000, it would fire right up, it also added some throttle response, woke the engine right up.
800screws
EVO
28
Aug 16, 2016 11:31 AM
rprider
Exhaust System Topics
Jun 24, 2012 07:15 PM
bigjohn68
Feb 28, 2011 03:00 PM
SBC427
15
Apr 22, 2010 07:24 AM
94 FXDL
11
Mar 6, 2010 10:55 AM
