Thunder Jet
Old Jan 18, 2020 | 08:03 PM
natural gasser's Avatar
natural gasser
31 intermediate, 80 main when it ran ok. Now after the dyno tune, 31 intermediate and 78 main. the tuner is the one who said what the afr was.
Old Jan 18, 2020 | 09:37 PM
1997bagger's Avatar
1997bagger
Originally Posted by natural gasser
Plugs looked a little sooty when it ran good. Mileage was terrible running the 2 lane roads at 55 mph. Lucky to get 29 miles per gallon.
1997 Bagger what do you mean by tuning idle to 1500 rpm's?
Use the air/fuel idle screw to remove your problems from idle to 1500 rpms is the answer to the question. Your main problem is in the 1500 rpm and below area controlled by the air/fuel screw, it is lean and causes a intake pop, exhaust gurgle/pop and hard starts. Turn your air/fuel screw out in 1/2 turn increments until the pop goes away and stop.
On the bigger picture is a 31 on a 113" will be pig rich, more like a 29.5 intermediate is going to be closer instead of a 31 and if it is running 10.5 afr at wide open throttle you'll need to drop the big jet more, can't see any dyno tuner turning loose a Harley engine at 10.5 back onto the street, it's leaving horsepower on the table unless he didn't want to f*ck with a carb, it's not tuned right
Old Jan 18, 2020 | 09:44 PM
1997bagger's Avatar
1997bagger
He adjusted your air/screw lean causing all of the problems, find another dyno tuner, this one isn't doing you justice.
Old Jan 19, 2020 | 11:38 AM
natural gasser
Thank you all for the advice, appreciated.
Old Jan 24, 2020 | 11:49 AM
Oldskewl's Avatar
Oldskewl
A 78 main jet on a 113" motor? I run an 80 main on the shovel (S&S-E) and it purrs like a kitten, no decel pop.
Old Jan 24, 2020 | 12:40 PM
Racepres's Avatar
Racepres
Just so you understand all a thunder jet does is help correct a lean condition in the higher RPM ranges, not much help under 4500 PRM if the carbs halfway tuned correctly. You a street racer or strip guy go for it other wise average rider sees no gain.
Oh and for what it's worth my 93" HiPo shovel with an " E " only gets 36 to 38 mpg tops if I ride like a newbie, get the happy hand going on that drop's under 30 quick.
And I use it to get rid of the "sag" at the transition from intermediate to main jet...It really can make the S&S a better Carb... If tuned appropriately.. ie think of the Thunderjet as the Main and the Main as a High intermediate...Remembering all circuits are active [Cumulative] at WOT and RPM..
Note; If you are not adjusting the air bleed... you are Not tuning the Thunderjet-S&S
Old Feb 2, 2020 | 03:12 PM
natural gasser
He didn't turn it loose @ 10.5 afr, that is what it was when I brought it to him, least that's what he said. If the 31 Intermediate is "pig rich" then my pop on decel must not be a lean pop, correct? Exhaust decel pop even happens at 4000rpm.
Old Feb 2, 2020 | 08:03 PM
Dr.Hess's Avatar
Dr.Hess
Lean pop is out the carb.
Old Feb 3, 2020 | 07:18 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Twisted is absolutely correct, the thunder jet really doesn't become active till around 4200-4300 RPM. Some little sooner some a little later, it depends on the velocity of air going through the Venturi creating the lower pressure to drag the fuel up into the jet. the reason I use one is both for performance and better fuel management I have a very built 96" Evo where I can utilize that. The whole idea is to decrease the overlap of fuel creating a rich condition as the main jet transitions in and now cause a lean condition above 5000 RPM. Another words you can use a smaller main jet where it normally transitions in around 2800 RPM and not cause a rich condition at that RPM because the jet was too big. so now you only need the main jett to carry you from roughly 2800 RPM to 4200 RPM because the thunder jet will take over from there so you would definitely be running a smaller main jet if you're going to run a thunder jet.. It is a pretty good concept but you really need to know how to tune it.. As for the air bleed, its role is to allow what RPM range you want the main jet to come in at. The bigger the air bleed the later the circuit on the main jett will become active..
As bagger also said, turn out your idle mixture screw and go from there..
Old Feb 4, 2020 | 07:40 AM
Racepres's Avatar
Racepres
granted the thunderjet itself can only affect the carburetion at higher RPM
if you are remiss in utilizing it as a System in order to enhance the midrange with the other jets/airbleed
you have wasted time and effort even fooling with the Thunderjet
