Difference between two cylinder head serial numbers
Old Jan 18, 2020 | 03:07 PM
al0311's Avatar
al0311
Default Difference between two cylinder head serial numbers
Hey guys quick question I’m might need to purchase a new rear cylinder head the one I have is serial number 16720-84a and I found one online for a decent price but it’s stamped 16720-84. Would that One still be compatible with my bike? Thanks in advance
Old Jan 18, 2020 | 03:20 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Yes it is,
The letter designator behind a part number changes when Harley sources the part from a different place or material it's made from is upgraded but the basic design doesn't change.
Old Jan 18, 2020 | 03:24 PM
al0311's Avatar
al0311
Thank you so much for the quick reply thank you again I scratched the inside of the valve guide pretty bad taking the valve out and being careless.
Old Jan 18, 2020 | 04:11 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Wouldn't it be cheaper to have the guide replace?
Old Jan 18, 2020 | 05:20 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Seems like a drastic way to repair a small problem...
But I`m not an expert on HD cylinder heads.
Old Jan 18, 2020 | 06:37 PM
al0311's Avatar
al0311
My only option would be to remove the valve guides or hone them out correct ?
Old Jan 18, 2020 | 07:38 PM
98hotrodfatboy
No.. take it to a local shop and have them press out the old one and press in a new one... Very easy for a credited shop..
RidemyEVO
EVO
31
Mar 6, 2026 04:49 PM
hdrider98ci
Mar 21, 2019 10:31 PM
happyhab
EVO
27
Jun 10, 2016 11:05 AM
Bohemian
Shovelhead
May 1, 2013 08:52 PM
Bromano
Exhaust System Topics
Aug 31, 2010 02:13 PM
