My personal view on having an oil pressure gauge is: Don't. And I've had at least four on my 93 since new. Two HD (MoCo accessory gauges that hooked to a rocker box bolt using a longish tube to the tappet filter plug), one Accel, and one either Custom Chrome or Drag Specialties (can't remember). Both the latter, hooked directly to the tappet filter plug with a fitting. All liquid filled. They all eventually leaked out the silicone. For the most part they were just trinkets on the engine. I pulled the last one off a good ten or so years ago, and haven't missed it one bit.
I'll second.... Don't do it... but, by all means, keep the lite
Here's a third vote for not using one.
EVO's depend way more on flow than pressure and will just cause you to worry about something that isn't a problem.
As long as the light is off you're good.
My favourite local indy loathes the darned things with a passion, reckons they are more trouble than they are worth, because owners start hyper-ventilating over 'pressure'. For your own sanity pass on that idea and enjoy the rest of your life!
I may have a solution. I used to sell kits for oil pressure gauges for old Honda V4's. It used a few fittings to tap into the factory oil pressure sensor for the idiot light creating a T and allowed the use of a small liquid filled gauge.
I don't know where the oil sensor is on your bike, for if you're interested in the idea PM me and I'll send a few pics of what I did.
Nothing wrong with a back up.. when I bought my Fatboy in 03 it came with a liquid filled gauge.. Never leaked and it's still there.. don't know the brand.. never looked into it... I'm kinda a stickler on oil pressure and temps but to each their own..
because this aint yer dads pickup truck, it is a plain bearing engine
Harleys only require enough "pressure" to provide the appropriate Flow
which aint much at all
spend the money on yer Chevy
