Back fire through carb
Old Feb 18, 2020 | 04:08 PM
al0311's Avatar
al0311
Default Back fire through carb
Hey guys so I got the bike all put back together and start it up it starts back firing through the carb sometimes with flames lol. The only way to keep it running is to throttle it otherwise it dies. I recently did the top end on it new jugs pistons and rings. I lapped in new valve and seals. I didn’t make any adjustments with the carb or cam or anything else. It did not do this before the rebuild. It’s a 1987 flhtc evo . Thanks in advance .
Old Feb 18, 2020 | 04:21 PM
daven9113's Avatar
daven9113
Check air leak at carb manifold.
Old Feb 18, 2020 | 04:26 PM
RDHIGH's Avatar
RDHIGH
Did you increase displacement? Usually a sneeze out the carb is a lean condition. If you did increase- then id rejet the carb. If you didnt-Id recheck your timing.
but the manifold seal thing makes more sense.
Old Feb 18, 2020 | 04:28 PM
t150vej's Avatar
t150vej
Did you get your voes hooked back up and vacuum hose connected to the carb?
If yes, you have a bad intake leak, probably where the rubber compliance fittings bolt to the heads.
Old Feb 18, 2020 | 04:35 PM
al0311's Avatar
al0311
oh yeah I got that lol it was hiding under the seat when I took it off .
Old Feb 18, 2020 | 04:52 PM
al0311's Avatar
al0311
okay will do. Not looking forward to taking the gas tank off again but I guess I’ll have to
Old Feb 18, 2020 | 05:54 PM
Mountainkowboy's Avatar
Mountainkowboy
I have a hanging 1/2 gallon lawn edger fuel tank that I like to use for "first startups"
Old Feb 18, 2020 | 06:32 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Stock or adjustable pushrods?
Old Feb 18, 2020 | 07:01 PM
RDHIGH's Avatar
RDHIGH
Before you take the tank off-if you can find a small mirror and flashlight to look at the manifold and maybe you can spot something obvious-. If you can keep it running a bit- you can try spraying carb cleaner- or wd40 at the joints to note any rpm changes and try to narrow it down.
Old Feb 18, 2020 | 07:08 PM
RANGER73's Avatar
RANGER73
I had this problem after my Cam change. I needed to increase to idle until I could adjust the idle needle to make it richer.
